I’ve just upgraded today from 1.8.3 to the Ubuntu package for 2.0.0~b5. It’s gone semi-smoothly, a bunch of stuff still doesn’t work (like most of my zwave devices, until I bind them to the right channel, but all my items aren’t showing up so I can’t seem to do that).
Anyway, some zwave devices (mostly single relay switches) are all showing up as unknown devices. I’ve tried removing them, and adding again (using PaperUI) but they just are added again as unknown.
Strangely, some information has been populated, like below:
I’m using the OH2 zwave addon.
openhab-binding-zwave | 2.0.0.b5 | x | Started | openhab-aggregate-xml | Z-Wave Binding
Can anyone suggest what I might do to fix this?
The other issue, is that a certain .item file is causing 500 errors. The error from my browser, which shows up mostly when browsing items, is:
And the item file itself is below. It only occurs when the item file is in place - if I remove it, no errors.
Group Security
Group:Contact:AND(CLOSED,OPEN) Doors "Doors [(%d)]" <door> (Security)
Group:Contact:AND(CLOSED,OPEN) DoorsExternal "External Doors [MAP(doorsExternal.map):%d]" <door> (Doors)
Contact Door_DeckDoor "Deck door [%s]" <door> (DoorsExternal) { zwave="2:command=SWITCH_BINARY,respond_to_basic=TRUE" }
Number Sensor_DeckDoorBattery "Deck door [%.0f %%]" <battery_full> (SensorBattery100) { zwave="2:command=BATTERY" }
Contact Door_FrontDoor "Front door [%s]" <door> (DoorsExternal) { zwave="18:command=SWITCH_BINARY,respond_to_basic=TRUE" }
Number Sensor_FrontDoorBattery "Front door [%.0f %%]" <battery_full> (SensorBattery100) { zwave="18:command=BATTERY" }
Contact Door_DownstairsDoor "Downstairs door [%s]" <door> (DoorsExternal) { zwave="41:command=SWITCH_BINARY,respond_to_basic=TRUE" }
Number Sensor_DownstairsDoorBattery "Downstairs door [%.0f %%]" <battery_full> (SensorBattery100) { zwave="41:command=BATTERY" }
Contact Door_CourtyardDoor "Courtyard door [%s]" <door> (DoorsExternal) { zwave="5:command=SWITCH_BINARY,respond_to_basic=TRUE" }
Number Sensor_CourtyardDoorBattery "Courtyard door [%.0f %%]" <battery_full> (SensorBattery100) { zwave="5:command=BATTERY" }
Contact Door_LaundryDoor "Laundry door [%s]" <door> (DoorsExternal) { zwave="21:command=SWITCH_BINARY,respond_to_basic=TRUE" }
Number Sensor_LaundryDoorBattery "Laundry door [%.0f %%]" <battery_full> (SensorBattery100) { zwave="21:command=BATTERY" }
Switch garageDoor_Opener "plug" (lights2) { mqtt=">[mosquitto:home/garage/in/0:command:ON:1],>[mosquitto:home/garage/in/0:command:OFF:0]" }
Number garageDoor "Garage [MAP(contact.map):%s]" { mqtt="<[mosquitto:home/garage/out/0:state:default]" }
Switch garageDoor_Refresh "Refresh Garage" <controller> (Network) { mqtt=">[moquitto:home/garage/out/0/refresh:command:ON:1]", autoupdate="false" }
Contact VT_Lock_Locked "Locked [MAP(VTLockStateMap.map):%d]" <door>
Number VT_Lock_State "Door state [MAP(VTLockStateIDMap.map):%d]" <door>
String VT_Lock_StateName "State" <door>
Switch VT_Lock_BatteryCritical "Battery level" <door>
Switch VT_Lock_Action "Lock / unlock" <door> { http=">[ON:GET:http://nuki-bridge:8080/lockAction?token=aa&nukiId=11&action=2] >[OFF:GET:http://nuki-bridge:8080/lockAction?token=aa&nukiId=11&action=1]" }
