This is the first time I am using groups so I am not sure if this is an issue or I am missing something.
I am on OH2 and I used PaperUI to create a group item of switch type. If I create another switch item using PaperUI and add it to the group then I can toggle the switch by toggling the group item which I have added to the site map. This is the group definition from the file org.eclipse.smarthome.core.items.Item.json:
"LivingRoomPower": {
"class": "org.eclipse.smarthome.core.items.ManagedItemProvider$PersistedItem",
"value": {
"baseItemType": "Switch",
"groupNames": [],
"itemType": "Group",
"tags": [],
"label": "LivingRoomPower",
"category": "Test",
"functionName": "OR",
"functionParams": [
"ON",
"OFF"
I have another item which I have defined in panasonictv.items and not using PaperUI (this is because panasonictv does not have OH2 binding). If I add this item to a group using below syntax it is not affected when I toggle the group item. This is from panasonictv.items:
Switch LivingRoomTVPower "Power" (LivingRoomPower) {panasonictv="livingroom_panasonic_viera:POWER"}
In my sitemap file I have added the group switch:
Switch item=LivingRoomPower
