-100 No answer from device. (sending setValue()
Hi everyone,
since a couple of days I get this error with a homematic device which was working fine the last years. I’m on openhab 3 and homegear (all latest versions).
The device shows online as such but I can’t send any commands…
I saw that some others had similar issues as well but no solution which I could transfer to my environment. Any Idea how to investigate this error any furhter?
MM
IEQ0343999:1
STATE
true
java.io.IOException: -100 No answer from device. (sending setValue()
IEQ0343999:1
STATE
true
at org.openhab.binding.homematic.internal.communicator.parser.RpcResponseParser.parse(RpcResponseParser.java:51) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:82) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:94) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:70) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.client.RpcClient.setDatapointValue(RpcClient.java:335) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway$1.execute(AbstractHomematicGateway.java:686) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.misc.DelayedExecuter.start(DelayedExecuter.java:65) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.sendDatapoint(AbstractHomematicGateway.java:665) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.sendDatapoint(AbstractHomematicGateway.java:644) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.handler.HomematicThingHandler.sendDatapoint(HomematicThingHandler.java:312) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.handler.HomematicThingHandler.handleCommand(HomematicThingHandler.java:288) [bundleFile:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy787.handleCommand(Unknown Source) [?:?]
at org.openhab.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:80) [bundleFile:?]
at org.openhab.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
What kind of device is it? I use homegear and a cul stick to operate Max devices. These devices have a duty cycle limit, meaning that they can only transmit 1% of the time. After that limit is exhausted, no further command will be sent until the device is allowed to communicate again. If I exceed the duty cycle limit, I get errors like yours.
