I have a Gardena Soil sensor.
I want to display the values of this thing.
But it formats as 100 one instead of 100%.
How can I modify this model/thing so it properly displays the value.
how does your current setup look like ?
Make it Number:Dimensionless
type.
Change state description pattern to %.0f %%
. You most likely have %unit%
in it.
Thanks for your suggestions.
%.0f %% makes it 10000% instead of 100 one
and
It’s already Number:Dimensionless.
From the docs, I would assume, the binding does not support UoM, therefore it would be just Number
and state description %.0f %%
Yes, removing the Dimensionless did the trick.
