thanks, that did the trick
I’ve removed it but getting this error time and time again
root@openhab-slave-eg:/var/log/openhab2# grep “Failed installing ‘openhab-misc-restdocs’” openhab.log
2019-12-31 16:28:37.452 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-misc-restdocs’
2019-12-31 16:28:53.756 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-misc-restdocs’
2019-12-31 16:29:30.659 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-misc-restdocs’
2019-12-31 16:30:38.256 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-misc-restdocs’
2019-12-31 16:31:32.325 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-misc-restdocs’
" REST Docs
This add-on is now part of the UIs. When previously installed using a UI, uninstall the REST Docs before updating and reinstall it after the update to prevent errors. When installing it using textual configuration, update services/addons.cfg
by removing restdocs
from misc
and add it to ui
instead."
If you updated the addons and it is still giving error you can try clearing the cache
openHABianPi:~$ sudo systemctl stop openhab2.service
openHABianPi:~$ sudo openhab-cli clean-cache
This command will delete the temporary files within openHAB.
May resolve issues with addon installation and configuration.
The next start of openHAB will take a bit longer.
Okay to Continue? [y/N]: y
openHABianPi:~$ sudo systemctl start openhab2.service
In addition to @denominator post you may need to restart OH a few times. I had to reboot then restart OH 3 times to get everything working.
If that does not work then downgrade and uninstall restdocs, clean cache, restart OH then upgrade. After the upgrade you can reinstall the restdocs vai PaperUI.
After some tries I’ve found a file in
/var/lib/openhab2/config/org/openhab/addons.config
After removing it there, it stops installing the restdocs.
That did it for me (openhabian installed on a machine running Ubuntu 18.04). All other suggestions earlier in this thread did not work.
