Java Runtime Environment: _which java platform is used and what version ???
openHAB version: downloaded 2.0
Issue of the topic: please be detailed explaining your issue:
When I run C:\users\owner>c:\openhab2\start.bat, I get error “… cannot run JAVA_HOME IS NOT VALID…” [c:\program files (x86)\JAVA\jre1.8.0\Java] … and: “cannot fine the batch label…/ kARAF.bat: ignoring predefined value for karaf_HOME.”
IS THERE A SERVICE THAT REMOTELY CAN ASSIST IN SETUP???
No, but we have great docs were you can find all steps needed, in your case I guess you did not set the java_home correctly or your java version is too old.
Thank you for your response. I guess I’m not cut out for this. My sys variable has [C:\Program Files\Java\jdk-9.0.1] Now get error “could not create java virtual machine…” Again Thx
I’m hooked. I need to figure this out. I got it installed (I think) and logged into (my machine IP:8080) and in the Paper UI, I added routines, things, etc. Question: I cannot add any of my Z- Wave devices. I use Samsung Smartthing hub (ST-Hub.) I get the feeling that I need a “USB series controller??” Is this the fix” Does it work together with ST-hub?? Or will I have to remove my ST Hub? Would appreciate any advice or recommendation [aside from… that I should give this up]
