After installing openhabian-config, Optional Components, 1wire I get
│ Setup was successful. │
│ Next, please configure your system in /etc/owfs.conf. │
│ Use # to comment/deactivate a line. All you should have to change is the │
│ following. Deactivate │
│ server: FAKE = DS18S20,DS2405 │
│ and activate one of these most common options (depending on your device): │
│ #server: usb = all │
│ #server: device = /dev/ttyS1 │
│ #server: device = /dev/ttyUSB0 │
My /etc/owfs.conf
# Sample configuration file for the OWFS suite for Debian GNU/Linux.
# This is the main OWFS configuration file. You should read the
# owfs.conf(5) manual page in order to understand the options listed
# here.
######################## SOURCES ########################
# With this setup, any client (but owserver) uses owserver on the
# local machine...
! server: server = localhost:4304
# ...and owserver uses the real hardware, by default fake devices
# This part must be changed on real installation
# USB device: DS9490
#server: usb = all
# Serial port: DS9097
# owserver tcp address
#server: server = 192.168.10.1:3131
# random simulated device
#server: FAKE = DS18S20,DS2405
######################### OWFS ##########################
#mountpoint = /mnt/1wire
#allow_other
####################### OWHTTPD #########################
http: port = 2121
####################### OWFTPD ##########################
ftp: port = 2120
####################### OWSERVER ########################
server: port = localhost:4304
I want to use RaspberryPi3 GPIO04 for 1wire. With lines are to activate?
