I just went into edit in paper UI then hit the tick to exit it, and it reinitialise something, but usure if that should clear it:
2020-04-20 10:38:00.755 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update received
2020-04-20 10:38:00.758 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update set action_heal to true (Boolean)
2020-04-20 10:38:00.759 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Starting heal on node!
2020-04-20 10:38:00.760 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Can not start heal as initialisation is not complete (UPDATE_NEIGHBORS).
2020-04-20 10:38:41.005 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update received
2020-04-20 10:38:41.008 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored binding_cmdrepollperiod to 1500 (BigDecimal)
2020-04-20 10:38:41.010 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_100_1_wo to 0 (BigDecimal)
2020-04-20 10:38:41.011 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_91_2 to 25 (BigDecimal)
2020-04-20 10:38:41.012 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_92_1 to 5 (BigDecimal)
2020-04-20 10:38:41.013 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update set group_4 to null (null)
2020-04-20 10:38:41.014 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Association 4 consolidated to []
2020-04-20 10:38:41.015 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Current members before update ZWaveAssociationGroup [index=4, name=Control:Key2, profile1=32, profile2=2, associations=[]]
2020-04-20 10:38:41.017 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Members after config update ZWaveAssociationGroup [index=4, name=null, profile1=null, profile2=null, associations=[]]
2020-04-20 10:38:41.018 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Controller is master - forcing associations
2020-04-20 10:38:41.022 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Handler disposed. Unregistering listener.
2020-04-20 10:38:41.022 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Members after controller update ZWaveAssociationGroup [index=4, name=null, profile1=null, profile2=null, associations=[]]
2020-04-20 10:38:41.024 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Association group 4 contains no members. Clearing.
2020-04-20 10:38:41.025 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 11: Creating new message for application command ASSOCIATIONCMD_REMOVE group=4, node=all
2020-04-20 10:38:41.026 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2020-04-20 10:38:41.027 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2020-04-20 10:38:41.028 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:38:41.029 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3061 to queue - size 1
2020-04-20 10:38:41.032 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 04 04 25 22 6C
2020-04-20 10:38:41.036 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 11: Creating new message for application command ASSOCIATIONCMD_GET group 4
2020-04-20 10:38:41.037 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2020-04-20 10:38:41.038 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2020-04-20 10:38:41.039 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:38:41.041 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3062 to queue - size 1
2020-04-20 10:38:41.043 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 11: Serializing to file /openhab/userdata/zwave/network_c275b7eb__node_11.xml
2020-04-20 10:38:41.044 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_90_1 to 0 (BigDecimal)
2020-04-20 10:38:41.050 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:38:41.051 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3061: Transaction not completed
2020-04-20 10:38:41.045 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored group_1 to [controller] (ArrayList)
2020-04-20 10:38:41.055 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Controller status changed to ONLINE.
2020-04-20 10:38:41.056 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Controller is ONLINE. Starting device initialisation.
2020-04-20 10:38:41.056 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Association 3 consolidated to []
2020-04-20 10:38:41.057 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Updating node properties.
2020-04-20 10:38:41.058 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Current members before update ZWaveAssociationGroup [index=3, name=Control:Key1, profile1=32, profile2=1, associations=[]]
2020-04-20 10:38:41.058 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Updating node properties. MAN=134
2020-04-20 10:38:41.059 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Members after config update ZWaveAssociationGroup [index=3, name=null, profile1=null, profile2=null, associations=[]]
2020-04-20 10:38:41.060 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Updating node properties. MAN=134. SET. Was 134
2020-04-20 10:38:41.061 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Controller is master - forcing associations
2020-04-20 10:38:41.061 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Properties synchronised
2020-04-20 10:38:41.064 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Update ASSOCIATION group_ZWaveAssociationGroup [index=1, name=Lifeline, profile1=0, profile2=1, associations=[node_1]]: Adding Controller (node_1)
2020-04-20 10:38:41.065 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration synchronised
2020-04-20 10:38:41.065 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Members after controller update ZWaveAssociationGroup [index=3, name=null, profile1=null, profile2=null, associations=[]]
2020-04-20 10:38:41.067 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Association group 3 contains no members. Clearing.
2020-04-20 10:38:41.069 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 11: Creating new message for application command ASSOCIATIONCMD_REMOVE group=3, node=all
2020-04-20 10:38:41.070 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising Thing Node...
2020-04-20 10:38:41.094 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising cmd channel zwave:device:a5365e91:node11:switch_binary for OnOffType
2020-04-20 10:38:41.095 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising state channel zwave:device:a5365e91:node11:switch_binary for OnOffType
2020-04-20 10:38:41.096 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising cmd channel zwave:device:a5365e91:node11:scene_number for DecimalType
2020-04-20 10:38:41.097 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising state channel zwave:device:a5365e91:node11:scene_number for DecimalType
2020-04-20 10:38:41.097 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising cmd channel zwave:device:a5365e91:node11:meter_watts for DecimalType
2020-04-20 10:38:41.098 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising state channel zwave:device:a5365e91:node11:meter_watts for DecimalType
2020-04-20 10:38:41.099 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising cmd channel zwave:device:a5365e91:node11:meter_voltage for DecimalType
2020-04-20 10:38:41.099 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising state channel zwave:device:a5365e91:node11:meter_voltage for DecimalType
2020-04-20 10:38:41.092 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2020-04-20 10:38:41.100 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising cmd channel zwave:device:a5365e91:node11:meter_kwh for DecimalType
2020-04-20 10:38:41.101 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2020-04-20 10:38:41.101 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising state channel zwave:device:a5365e91:node11:meter_kwh for DecimalType
2020-04-20 10:38:41.102 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:38:41.102 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising cmd channel zwave:device:a5365e91:node11:meter_current for DecimalType
2020-04-20 10:38:41.103 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3063 to queue - size 2
2020-04-20 10:38:41.103 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising state channel zwave:device:a5365e91:node11:meter_current for DecimalType
2020-04-20 10:38:41.104 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising cmd channel zwave:device:a5365e91:node11:meter_reset for OnOffType
2020-04-20 10:38:41.105 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 11: Creating new message for application command ASSOCIATIONCMD_GET group 3
2020-04-20 10:38:41.105 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising state channel zwave:device:a5365e91:node11:meter_reset for OnOffType
2020-04-20 10:38:41.106 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2020-04-20 10:38:41.106 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising cmd channel zwave:device:a5365e91:node11:alarm_power for OnOffType
2020-04-20 10:38:41.107 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2020-04-20 10:38:41.107 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising state channel zwave:device:a5365e91:node11:alarm_power for OnOffType
2020-04-20 10:38:41.107 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:38:41.108 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising cmd channel zwave:device:a5365e91:node11:alarm_heat for OnOffType
2020-04-20 10:38:41.109 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3064 to queue - size 3
2020-04-20 10:38:41.109 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising state channel zwave:device:a5365e91:node11:alarm_heat for OnOffType
2020-04-20 10:38:41.110 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising cmd channel zwave:device:a5365e91:node11:time_offset for DecimalType
2020-04-20 10:38:41.111 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update set group_2 to null (null)
2020-04-20 10:38:41.112 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Initialising state channel zwave:device:a5365e91:node11:time_offset for DecimalType
2020-04-20 10:38:41.112 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Association 2 consolidated to []
2020-04-20 10:38:41.113 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Polling initialised at 86400 seconds - start in 66787200 milliseconds.
2020-04-20 10:38:41.113 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Current members before update ZWaveAssociationGroup [index=2, name=Retransmit, profile1=0, profile2=0, associations=[]]
2020-04-20 10:38:41.114 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Device initialisation complete.
2020-04-20 10:38:41.115 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Members after config update ZWaveAssociationGroup [index=2, name=null, profile1=null, profile2=null, associations=[]]
2020-04-20 10:38:41.118 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Controller is master - forcing associations
2020-04-20 10:38:41.124 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Members after controller update ZWaveAssociationGroup [index=2, name=null, profile1=null, profile2=null, associations=[]]
2020-04-20 10:38:41.125 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Association group 2 contains no members. Clearing.
2020-04-20 10:38:41.126 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 11: Creating new message for application command ASSOCIATIONCMD_REMOVE group=2, node=all
2020-04-20 10:38:41.127 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2020-04-20 10:38:41.128 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2020-04-20 10:38:41.129 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:38:41.130 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3065 to queue - size 4
2020-04-20 10:38:41.132 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 11: Creating new message for application command ASSOCIATIONCMD_GET group 2
2020-04-20 10:38:41.133 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: SECURITY not supported
2020-04-20 10:38:41.134 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2020-04-20 10:38:41.135 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:38:41.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3066 to queue - size 5
2020-04-20 10:38:41.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored switchall_mode to 255 (BigDecimal)
2020-04-20 10:38:41.139 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored action_reinit to false (Boolean)
2020-04-20 10:38:41.140 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_112_4 to 600 (BigDecimal)
2020-04-20 10:38:41.141 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_113_4 to 600 (BigDecimal)
2020-04-20 10:38:41.142 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_111_4 to 60 (BigDecimal)
2020-04-20 10:38:41.143 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_20_1 to 0 (BigDecimal)
2020-04-20 10:38:41.144 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_84_4 to 301991936 (BigDecimal)
2020-04-20 10:38:41.145 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_83_1 to 0 (BigDecimal)
2020-04-20 10:38:41.146 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_82_1 to 1 (BigDecimal)
2020-04-20 10:38:41.147 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_252_1 to 0 (BigDecimal)
2020-04-20 10:38:41.148 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_81_1 to 1 (BigDecimal)
2020-04-20 10:38:41.149 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_80_1 to 3 (BigDecimal)
2020-04-20 10:38:41.150 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_255_4 to 0 (BigDecimal)
2020-04-20 10:38:41.151 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored action_failed to false (Boolean)
2020-04-20 10:38:41.152 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored action_remove to false (Boolean)
2020-04-20 10:38:41.153 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_110_1_wo to 0 (BigDecimal)
2020-04-20 10:38:41.154 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored binding_pollperiod to 86400 (BigDecimal)
2020-04-20 10:38:41.155 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored action_heal to false (Boolean)
2020-04-20 10:38:41.156 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_122_1 to 3 (BigDecimal)
2020-04-20 10:38:41.157 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_120_1 to 1 (BigDecimal)
2020-04-20 10:38:41.158 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_121_1 to 0 (BigDecimal)
2020-04-20 10:38:41.159 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_101_4 to 2 (BigDecimal)
2020-04-20 10:38:41.159 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_102_4 to 1 (BigDecimal)
2020-04-20 10:38:41.160 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_9_1 to 0 (BigDecimal)
2020-04-20 10:38:41.161 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_3_1 to 1 (BigDecimal)
2020-04-20 10:38:41.162 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_4_1 to 0 (BigDecimal)
2020-04-20 10:38:41.163 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_87_4 to 8327680 (BigDecimal)
2020-04-20 10:38:41.164 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_103_4 to 4 (BigDecimal)
2020-04-20 10:38:41.165 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored node_id to 11 (BigDecimal)
2020-04-20 10:38:41.166 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Configuration update ignored config_86_4 to 8327680 (BigDecimal)
2020-04-20 10:38:41.661 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 34, Status = Transmission complete, no ACK received(1)
2020-04-20 10:38:41.662 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:41.663 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: CANCEL while sending message. Requeueing - 2 attempts left!
2020-04-20 10:38:41.664 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:38:41.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3061 to queue - size 6
2020-04-20 10:38:41.666 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 04 04 25 23 6D
2020-04-20 10:38:41.668 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3061: Transaction not completed
2020-04-20 10:38:41.686 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:38:41.687 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3061: Transaction not completed
2020-04-20 10:38:43.800 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 35, Status = Transmission complete, no ACK received(1)
2020-04-20 10:38:43.802 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:43.802 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: CANCEL while sending message. Requeueing - 1 attempts left!
2020-04-20 10:38:43.803 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:38:43.804 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3061 to queue - size 6
2020-04-20 10:38:43.806 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 04 04 25 24 6A
2020-04-20 10:38:43.809 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3061: Transaction not completed
2020-04-20 10:38:43.824 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:38:43.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3061: Transaction not completed
2020-04-20 10:38:43.927 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 36, Status = Transmission complete, no ACK received(1)
2020-04-20 10:38:43.928 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:43.929 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Retry count exceeded. Discarding message: TID 3061: [CANCELLED] priority=Config, requiresResponse=true, callback: 36
2020-04-20 10:38:43.930 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3061: Transaction completed
2020-04-20 10:38:43.930 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: notifyTransactionResponse TID:3061 CANCELLED
2020-04-20 10:38:43.931 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:43.934 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 02 04 25 25 6D
2020-04-20 10:38:43.953 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:38:43.954 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3062: Transaction not completed
2020-04-20 10:38:44.070 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 37, Status = Transmission complete, no ACK received(1)
2020-04-20 10:38:44.071 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:44.072 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: CANCEL while sending message. Requeueing - 2 attempts left!
2020-04-20 10:38:44.073 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:38:44.073 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3062 to queue - size 5
2020-04-20 10:38:44.075 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 02 04 25 26 6E
2020-04-20 10:38:44.077 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3062: Transaction not completed
2020-04-20 10:38:44.093 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:38:44.094 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3062: Transaction not completed
2020-04-20 10:38:44.166 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 38, Status = Transmission complete, no ACK received(1)
2020-04-20 10:38:44.167 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:44.167 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: CANCEL while sending message. Requeueing - 1 attempts left!
2020-04-20 10:38:44.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:38:44.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3062 to queue - size 5
2020-04-20 10:38:44.171 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 02 04 25 27 6F
2020-04-20 10:38:44.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3062: Transaction not completed
2020-04-20 10:38:44.190 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:38:44.191 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3062: Transaction not completed
2020-04-20 10:38:44.307 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 39, Status = Transmission complete, no ACK received(1)
2020-04-20 10:38:44.308 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:44.309 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Retry count exceeded. Discarding message: TID 3062: [CANCELLED] priority=Config, requiresResponse=true, callback: 39
2020-04-20 10:38:44.309 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3062: Transaction completed
2020-04-20 10:38:44.310 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: notifyTransactionResponse TID:3062 CANCELLED
2020-04-20 10:38:44.311 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:44.313 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 04 03 25 28 61
2020-04-20 10:38:44.332 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:38:44.333 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3063: Transaction not completed
2020-04-20 10:38:44.479 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 40, Status = Transmission complete, no ACK received(1)
2020-04-20 10:38:44.480 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:44.481 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: CANCEL while sending message. Requeueing - 2 attempts left!
2020-04-20 10:38:44.482 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:38:44.482 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3063 to queue - size 4
2020-04-20 10:38:44.484 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 04 03 25 29 60
2020-04-20 10:38:44.487 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3063: Transaction not completed
2020-04-20 10:38:44.502 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:38:44.503 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3063: Transaction not completed
2020-04-20 10:38:44.620 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 41, Status = Transmission complete, no ACK received(1)
2020-04-20 10:38:44.621 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:44.622 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: CANCEL while sending message. Requeueing - 1 attempts left!
2020-04-20 10:38:44.623 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:38:44.624 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3063 to queue - size 4
2020-04-20 10:38:44.626 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 04 03 25 2A 63
2020-04-20 10:38:44.627 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3063: Transaction not completed
2020-04-20 10:38:44.644 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:38:44.645 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3063: Transaction not completed
2020-04-20 10:38:44.746 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 42, Status = Transmission complete, no ACK received(1)
2020-04-20 10:38:44.747 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:44.748 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Retry count exceeded. Discarding message: TID 3063: [CANCELLED] priority=Config, requiresResponse=true, callback: 42
2020-04-20 10:38:44.749 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3063: Transaction completed
2020-04-20 10:38:44.749 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: notifyTransactionResponse TID:3063 CANCELLED
2020-04-20 10:38:44.750 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:44.752 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 02 03 25 2B 64
2020-04-20 10:38:44.770 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:38:44.772 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3064: Transaction not completed
2020-04-20 10:38:44.888 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 43, Status = Transmission complete, no ACK received(1)
2020-04-20 10:38:44.890 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:44.891 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: CANCEL while sending message. Requeueing - 2 attempts left!
2020-04-20 10:38:44.892 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:38:44.892 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3064 to queue - size 3
2020-04-20 10:38:44.894 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 02 03 25 2C 63
2020-04-20 10:38:44.896 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3064: Transaction not completed
2020-04-20 10:38:44.913 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:38:44.914 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3064: Transaction not completed
2020-04-20 10:38:45.060 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 44, Status = Transmission complete, no ACK received(1)
2020-04-20 10:38:45.062 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:45.062 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: CANCEL while sending message. Requeueing - 1 attempts left!
2020-04-20 10:38:45.063 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:38:45.064 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3064 to queue - size 3
2020-04-20 10:38:45.066 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 02 03 25 2D 62
2020-04-20 10:38:45.068 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3064: Transaction not completed
2020-04-20 10:38:45.085 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:38:45.087 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3064: Transaction not completed
2020-04-20 10:38:45.157 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 45, Status = Transmission complete, no ACK received(1)
2020-04-20 10:38:45.158 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:45.159 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Retry count exceeded. Discarding message: TID 3064: [CANCELLED] priority=Config, requiresResponse=true, callback: 45
2020-04-20 10:38:45.160 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3064: Transaction completed
2020-04-20 10:38:45.160 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: notifyTransactionResponse TID:3064 CANCELLED
2020-04-20 10:38:45.161 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:45.163 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 04 02 25 2E 66
2020-04-20 10:38:45.197 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:38:45.199 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3065: Transaction not completed
2020-04-20 10:38:49.297 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 46, Status = Transmission complete, no ACK received(1)
2020-04-20 10:38:49.298 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:49.299 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: CANCEL while sending message. Requeueing - 2 attempts left!
2020-04-20 10:38:49.300 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:38:49.301 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3065 to queue - size 2
2020-04-20 10:38:49.302 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 04 02 25 2F 67
2020-04-20 10:38:49.304 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3065: Transaction not completed
2020-04-20 10:38:49.321 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:38:49.322 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3065: Transaction not completed
2020-04-20 10:38:53.466 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 47, Status = Transmission complete, no ACK received(1)
2020-04-20 10:38:53.467 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:53.467 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: CANCEL while sending message. Requeueing - 1 attempts left!
2020-04-20 10:38:53.469 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:38:53.469 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3065 to queue - size 2
2020-04-20 10:38:53.471 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 04 02 25 30 78
2020-04-20 10:38:53.473 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3065: Transaction not completed
2020-04-20 10:38:53.489 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:38:53.491 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3065: Transaction not completed
2020-04-20 10:38:57.664 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 48, Status = Transmission complete, no ACK received(1)
2020-04-20 10:38:57.665 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:57.666 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Retry count exceeded. Discarding message: TID 3065: [CANCELLED] priority=Config, requiresResponse=true, callback: 48
2020-04-20 10:38:57.667 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3065: Transaction completed
2020-04-20 10:38:57.667 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: notifyTransactionResponse TID:3065 CANCELLED
2020-04-20 10:38:57.668 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:38:57.671 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 02 02 25 31 7F
2020-04-20 10:38:57.689 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:38:57.690 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3066: Transaction not completed
2020-04-20 10:39:01.025 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 49, Status = Transmission complete, no ACK received(1)
2020-04-20 10:39:01.026 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:39:01.027 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: CANCEL while sending message. Requeueing - 2 attempts left!
2020-04-20 10:39:01.028 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:39:01.029 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3066 to queue - size 1
2020-04-20 10:39:01.031 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 02 02 25 32 7C
2020-04-20 10:39:01.033 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3066: Transaction not completed
2020-04-20 10:39:01.050 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:39:01.051 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3066: Transaction not completed
2020-04-20 10:39:03.059 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 50, Status = Transmission complete, no ACK received(1)
2020-04-20 10:39:03.060 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:39:03.060 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: CANCEL while sending message. Requeueing - 1 attempts left!
2020-04-20 10:39:03.061 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Adding to device queue
2020-04-20 10:39:03.062 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Added 3066 to queue - size 1
2020-04-20 10:39:03.064 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 11: Sending REQUEST Message = 01 0A 00 13 0B 03 85 02 02 25 33 7D
2020-04-20 10:39:03.070 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3066: Transaction not completed
2020-04-20 10:39:03.087 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: sentData successfully placed on stack.
2020-04-20 10:39:03.088 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3066: Transaction not completed
2020-04-20 10:39:07.162 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 11: SendData Request. CallBack ID = 51, Status = Transmission complete, no ACK received(1)
2020-04-20 10:39:07.163 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-04-20 10:39:07.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: Retry count exceeded. Discarding message: TID 3066: [CANCELLED] priority=Config, requiresResponse=true, callback: 51
2020-04-20 10:39:07.165 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: TID 3066: Transaction completed
2020-04-20 10:39:07.165 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 11: notifyTransactionResponse TID:3066 CANCELLED
2020-04-20 10:39:07.166 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
