I ran an apt-get upgrade today against the snapshot repo and got
openHAB 2.5.0~S1754-1 (Build #1754)
Unfortunately the system does not start up.
There are no logs appended in /var/log/openhab2
systemctl says the process is running which I can confirm:
[14:51:46] openhabian@smart-controller:/var/log/openhab2$ ps ax |grep openhab2
480 ? Ssl 0:03 node /usr/bin/frontail --ui-highlight --ui-highlight-preset ./preset/openhab.json -t openhab -l 2000 -n 200 /var/log/openhab2/openhab.log /var/log/openhab2/events.log
1068 ? S 0:00 tail -n 200 -F /var/log/openhab2/openhab.log /var/log/openhab2/events.log
7855 ? Ssl 0:18 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/var/log/openhab2 -Dfelix.cm.dir=/var/lib/openhab2/config -Djava.library.path=/var/lib/openhab2/tmp/lib -Djetty.host=0.0.0.0 -Djetty.http.compliance=RFC2616 -Dorg.ops4j.pax.web.listening.addresses=0.0.0.0 -Dorg.osgi.service.http.port=8080 -Dorg.osgi.service.http.port.secure=8443 -Djava.awt.headless=true -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0:/dev/ttyS0:/dev/ttyS2:/dev/ttyACM0:/dev/ttyAMA0 -Djava.endorsed.dirs=/usr/lib/jvm/zulu-embedded-8-armhf/jre/lib/endorsed:/usr/lib/jvm/zulu-embedded-8-armhf/lib/endorsed:/usr/share/openhab2/runtime/lib/endorsed -Djava.ext.dirs=/usr/lib/jvm/zulu-embedded-8-armhf/jre/lib/ext:/usr/lib/jvm/zulu-embedded-8-armhf/lib/ext:/usr/share/openhab2/runtime/lib/ext -Dkaraf.instances=/var/lib/openhab2/tmp/instances -Dkaraf.home=/usr/share/openhab2/runtime -Dkaraf.base=/var/lib/openhab2 -Dkaraf.data=/var/lib/openhab2 -Dkaraf.etc=/var/lib/openhab2/etc -Dkaraf.log=/var/log/openhab2 -Dkaraf.restart.jvm.supported=true -Djava.io.tmpdir=/var/lib/openhab2/tmp -Djava.util.logging.config.file=/var/lib/openhab2/etc/java.util.logging.properties -Dkaraf.startLocalConsole=false -Dkaraf.startRemoteShell=true -classpath /usr/share/openhab2/runtime/lib/boot/org.apache.karaf.diagnostic.boot-4.2.7.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.jaas.boot-4.2.7.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.main-4.2.7.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.specs.activator-4.2.7.jar:/usr/share/openhab2/runtime/lib/boot/osgi.core-6.0.0.jar org.apache.karaf.main.Main
journald does not know anything besides:
Nov 12 14:40:13 smart-controller systemd[1]: Started openHAB 2 - empowering the smart home.
Anyone a quick pointer what to check or what might be wrong/how to analyze?
Alternatively any idea where to find earlier snapshots?
According to my apt log I had 2.5.0~S1733-1 before which was running at least still.
Platform information:
- Release = Raspbian GNU/Linux 9 (stretch)
- Kernel = Linux 4.19.66-v7+
- Platform = Raspberry Pi 3 Model B Rev 1.2
Issue of the topic: openhab2 does not start up; no logs in /var/log/openhab2
