Maybe - I have no information about your network. How many devices there are, if they are mains, where they are located etc so I’m just offering ideas.
Probably this is correct since routing is generally pretty static, however you probably can’t actually tell this
since there is nothing to tell you the routing (or maybe you have a sniffer?).
All mostly at the controller end of the house, I have started putting devices at the out reaches.
No sniffer just the si labs pc controller. Can that tell me routing? I know it can set routes, but the doco is a little sparse on how to do this, and what it should look like.
Not brick, Just timber, dry wall ( I think that’s what you call gib board in the us)
Node 19 is on the 2nd floor, Probably close to the node 7 which is in the little room at the bottom of the floor plan.
Generally the zwave has been good, but adding this last node has caused me no end of problems. It was generally working, and responding, but has since stopped.
So things kind of stablised. But there were a couple of nodes that would never move off ping or request_nif. So I let it do a heal over night. Most have come back, one was being annoying, so I’ve moved it 1m and it’s now got a signal. But again I’m left with a couple of devices that seem to work, but they are not completing their initialisation.
These did a heal at 3am, and it’s currently 7am. I know form previous experience, that these will never resolve. Is there anything I can do to help them along? Does sending commands to these devices (on, off, on, off) help it carry on the process? @chris
I did try removing one of the nodes that was sitting in update neighbours. Deleted it in paper ui. Waited a minute or so, then scanned zwave a re-added. Still seems to be in the same state.
Have I done that correctly? Or should I have deleted, and fully restarted openhab before trying to re-add?
Its definitely online, as I can see its power reports coming in every minute or so.
