I have 2 zwave dimmers, controlled via 2 physical buttons controlling 2 different lights
I would like to keep those lights always in sync and actually make them act like a single device…
my problem is that the dimmer actors slowly dim up and update that dim up with slowly eg increasing states in openhab
so if I check both dimmers for “updates” after a physival button press they would affect each other
example:
I press buton one: dimmer1 = shows now 100 in openhab
rule sees the state change and changes light 2 …
however while dimming up light 2 shows the states 30 …50 .80. 100 in sequence
now my other rule for checking state changes on dimmer 2 would actually fire and again change light one…
I hope my problem somehow is understandable
cheers
