Do I need separate lines in the config for the 2 thermostats?
Any idea what I’m missing in the config for the second thermostat to show up?
Another less important question is the following, when setting the temperature on the iphone in the homekit app for the thermostat that does show up the slider goes from -100 to + 100, is there a way to set the range (e.g. from 10°C to 30°C) ?
Did you solve this? I have two thermostats in my home, and it works correctly in HomeKit. You might try turning up logging and paste the logs here from a fresh restart. There’s a decent amount of log output as the HomeKit add-on parses your items.
Falk, no still having the -100 to +100 degrees range for the thermostats in Apple home app. So if anyone else found how to limit the range, I’m very interested.
The thermostat range of -100 thru +100 is due to a default setting in the HomeKit addon. I searched the source code and found that you can change this by configuring two additional parameters to the HomeKit Integration, for example like so:
minimumTemperature=8
maximumTemperature=30
If you use PaperUi, you must change to Expert Mode, then scroll down and select Add Parameter.
It would definitely make sense to expose these parameters in the UI, and also to change the defaults (which don’t seem to make sense at all).
I’d like to add that to the docs, too, but I don’t know how. Any hints?
