3D Printer Status and Commands from/to Octoprint via HTTP REST API
Hi all,
I succeeded getting the status of my 3D Printer which is controlled by Octoprint on a Raspberry Pi.
Update for OH3 thanks to @Mickroz :
Update: I also made a new implementation with the new MQTT Binding using octoprints new MQTT Plugin:
This is for OH2.x:
What you need:
  • openHAB2
  • HTTP Binding installed in OH2
  • JSONPATH Transformation installed in OH2
  • Octoprint installed
In Octoprint, go to Settings -> API. Enable API and CORS. Note down your API KEY.
Create a new *.items file (e.g. octoprint.items) and put the following code:
  • Replace “octopi.yourdomain” with what you type into your browser to access Octoprint
  • Replace “YOURAPIKEY” with your API KEY from the Octoprint front-end.
Create a new *.rules file (e.g. octoprint.rules) and put the follwing code:
A lot more commands could be added, the API is documented here: http://docs.octoprint.org/en/master/api/index.html
The “10000” in the HTTP item means it will pull new data every 10000ms or 10 seconds.
The JSONPATH command converts the JSON message into what you really need.
Enjoy!
// Octoprint
Group gOctoprint "Octoprint" (gAll)
String OctoprintPrinterState			"State [%s]"					                                (gOctoprint)	{http="<[http://octopi.yourdomain/api/connection?apikey=YOURAPIKEY:60000:JSONPATH($.current.state)]"}
String OctoprintPrinterProfile			"Profile [%s]"					                                (gOctoprint)	{http="<[http://octopi.yourdomain/api/connection?apikey=YOURAPIKEY:60000:JSONPATH($.current.printerProfile)]"}
String OctoprintPrinterCommand          "Printer Command"                                                       (gOctoprint)
String OctoprintSystemCommand          "System Command"                                                       (gOctoprint)
Number OctoprintJobEstimatedPrintTime	"Estimated Print Time [%.0f s]"	                <time>          (gOctoprint)	{http="<[http://octopi.yourdomain/api/job?apikey=YOURAPIKEY:60000:JSONPATH($.job.estimatedPrintTime)]"}
String OctoprintJobFileName				"Filename [%s]"					                                (gOctoprint)	{http="<[http://octopi.yourdomain/api/job?apikey=YOURAPIKEY:60000:JSONPATH($.job.file.name)]"}
Number OctoprintJobProgressCompletion	"Completion [%.0f %%]"					        <battery>       (gOctoprint)	{http="<[http://octopi.yourdomain/api/job?apikey=YOURAPIKEY:60000:JSONPATH($.progress.completion)]"}
Number OctoprintJobPrintTime			"Time Printed [%.0f s]"			                <time>	        (gOctoprint)	{http="<[http://octopi.yourdomain/api/job?apikey=YOURAPIKEY:60000:JSONPATH($.progress.printTime)]"}
String OctoprintJobPrintTimeString		"Time Printed [%s]"			                    <time>	        (gOctoprint)
Number OctoprintJobPrintTimeLeft		"Time Left [%.0f s]"			                <time>	        (gOctoprint)	{http="<[http://octopi.yourdomain/api/job?apikey=YOURAPIKEY:60000:JSONPATH($.progress.printTimeLeft)]"}
String OctoprintJobPrintTimeLeftString  "Time Left [%s]"			                    <time>	        (gOctoprint)
String OctoprintJobPrintETAString       "ETA [%s]"			                            <time>	        (gOctoprint)
DateTime OctoprintJobPrintETADateTime   "ETA [%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM]"    <time>          (gOctoprint)
String OctoprintPrinterPrintingState    "State [%s]"								                    (gOctoprint)    {http="<[http://octopi.yourdomain/api/printer?apikey=YOURAPIKEY:60000:JSONPATH($.state.text)]"}
Number OctoprintPrinterHotEndTemp		"Nozzle temp [%.1f °C]"		                    <temperature>	(gOctoprint)	{http="<[http://octopi.yourdomain/api/printer?apikey=YOURAPIKEY:60000:JSONPATH($.temperature.tool0.actual)]"}
Number OctoprintPrinterHotEndTempTarget	"Nozzle target [%.1f °C]"	                    <temperature>	(gOctoprint)	{http="<[http://octopi.yourdomain/api/printer?apikey=YOURAPIKEY:60000:JSONPATH($.temperature.tool0.target)]"}
Number OctoprintPrinterBedTemp			"Bed temp [%.1f °C]"		                    <temperature>	(gOctoprint)	{http="<[http://octopi.yourdomain/api/printer?apikey=YOURAPIKEY:60000:JSONPATH($.temperature.bed.actual)]"}
Number OctoprintPrinterBedTempTarget	"Bed target [%.1f °C]"		                    <temperature>	(gOctoprint)	{http="<[http://octopi.yourdomain/api/printer?apikey=YOURAPIKEY:60000:JSONPATH($.temperature.bed.target)]"}
rule "Time Printed String"
	Item OctoprintJobPrintTime changed
    val seconds = (OctoprintJobPrintTime.state as DecimalType).intValue
    val int totalMinutes = seconds/60
    val int remainderSecs = seconds%60
    val int totalHours = totalMinutes/60
    val int remainderMins = totalMinutes%60
    val formattedTime = String::format("%02d", totalHours) + ":" + String::format("%02d", remainderMins) + ":" + String::format("%02d", remainderSecs)
    OctoprintJobPrintTimeString.postUpdate(formattedTime)
rule "Time Left String"
	Item OctoprintJobPrintTimeLeft changed
    val seconds = (OctoprintJobPrintTimeLeft.state as DecimalType).intValue
    OctoprintJobPrintTimeLeftString.postUpdate(formattedTime)
    val DateTime OctoprintETA = now.plusSeconds(seconds)
    //logInfo("Testing" ,"Octoprint ETA: " + OctoprintETA.toString)
    OctoprintJobPrintETAString.postUpdate(OctoprintETA.toString)
    OctoprintJobPrintETADateTime.postUpdate(new DateTimeType(OctoprintETA.toString))
rule "POST Printer Command"
	Item OctoprintPrinterCommand received update
    var url = "http://octopi.yourdomain/api/job?apikey=YOURAPIKEY"
    var contenttype = "application/json"
    var POSTrequest = '{"command":"' +  OctoprintPrinterCommand.state + '"}'
    var output = sendHttpPostRequest(url, contenttype, POSTrequest)
    logInfo("Test Octoprint:", output);
rule "POST System Command"
	Item OctoprintSystemCommand received update
    var url = 'http://octopi.yourdomain/api/system/commands/core/' + OctoprintSystemCommand.state + '?apikey=YOURAPIKEY'
    //var contenttype = "application/json"
    var output = sendHttpPostRequest(url)
Perfect, it worked after installing the “JSONPath Transformation”. Maybe you can add this to your inital Post as a requirement. Thank you =)
I can´t get it to work.
the http binding and jasonpath is installed.
in the browser, I get some json data with e.g. http://192.168.178.22/api/printer?apikey=****[...]. so, the communication from the octoprint should be fine. but on the openhab side it´s not working.
In the items file, I used the same items as above but with “http=”<[http://192.168.178.22/api[...]"
Does anybody have an idea what could be wrong?
Hi all,
some time has passed and the Octoprint API has changed. I have updated the first post with the new configuration.
Also, I’ve added commanding of the most basic things: Job operations (start,cancel,pause) as well as system commands (shutdown,reboot).
Enjoy!
Hi @SpaceGlider,
really cool example. It worked out-of-the-box for me except the calculated values from the rules. They seems not to be executed and not showing errors.
Do you have an idea, how to solve this?
thanks in advance!
Norbert
Have you started a print? The values will only be calculated once they are being updated. For me this is usually about a few minutes into a print (or after the first layer?).
Maybe you changed item names? Otherwise no idea what could be wrong, as I copy-pasted it from my setup.
Cheers
David
Yes the printer is working, i just made copy paste with this result:
JSONPath Transformation is installed and i have added the items with “Text item” to the sitemap
It’s difficult to say what is wrong. I expect one of the following:
  • The .rules - file is not importet correctly. Check in the karaf if the file is loaded and there are no errors during import
  • You run an old OH version and need to add the java imports that do the calculations
I am running the actual stable release (i think it’s 2.1). The calculated values were updated :grinning: but with a very slow rate, i would say every 15minutes :thinking:.
I reduced the update time in the *.items file to 6000ms, but the rules were triggered less often.
Well that is great - so the rules are working!
I am running OH 2.2 beta from a few days ago on a Raspberry Pi 2 and I get updated values every 60 sec.
For everyone who wants to reboot/shutdown their Octoprint Raspi, you’re welcome:
Selection item=OctoprintSystemCommand mappings=[1="herunterfahren",2="Drucker neustarten",3="Service neustarten",4="Abgesicherten Modus starten"]
rule "POST System Kommando"
var String PrinterCmd = ""
    switch (OctoprintSystemCommand.state.toString){
    case "1":
    {PrinterCmd = "shutdown"}
    case "2":
    {PrinterCmd = "reboot"}
    case "3":
    {PrinterCmd = "restart"}
    case "4":
    {PrinterCmd = "restart_safe"}
    logInfo(filename, "Folgende Operation wurde auf den Ender 3 ausfĂźhrt: " + PrinterCmd )
    var url = 'http://octopi/api/system/commands/core/' + PrinterCmd + '?apikey=XXXXXXXXXXXX'
    logInfo(filename, output);
everything is working but i get warnings at my log when i shutdown the printer .
2018-11-30 16:20:53.819 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation 'JSONPATH($.temperature.bed.actual)' threw an exception. [response=Printer is not operational]
org.openhab.core.transform.TransformationException: Invalid path '$.temperature.bed.actual' in 'Printer is not operational'
	at org.openhab.core.transform.TransformationHelper$TransformationServiceDelegate.transform(TransformationHelper.java:67) [216:org.openhab.core.compat1x:2.3.0]
	at org.openhab.binding.http.internal.HttpBinding.execute(HttpBinding.java:194) [226:org.openhab.binding.http:1.12.0]
	at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:144) [216:org.openhab.core.compat1x:2.3.0]
	at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:166) [216:org.openhab.core.compat1x:2.3.0]
2018-11-30 16:20:53.987 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation 'JSONPATH($.temperature.tool0.target)' threw an exception. [response=Printer is not operational]
org.openhab.core.transform.TransformationException: Invalid path '$.temperature.tool0.target' in 'Printer is not operational'
2018-11-30 16:20:54.178 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation 'JSONPATH($.temperature.bed.target)' threw an exception. [response=Printer is not operational]
org.openhab.core.transform.TransformationException: Invalid path '$.temperature.bed.target' in 'Printer is not operational'
2018-11-30 16:20:54.202 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation 'JSONPATH($.temperature.tool0.actual)' threw an exception. [response=Printer is not operational]
org.openhab.core.transform.TransformationException: Invalid path '$.temperature.tool0.actual' in 'Printer is not operational'
2018-11-30 16:20:54.253 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation 'JSONPATH($.state.text)' threw an exception. [response=Printer is not operational]
org.openhab.core.transform.TransformationException: Invalid path '$.state.text' in 'Printer is not operational'
Me too, this is normal for unavailable http-binding stuff. Nothing much you can do except changing the logging level.
There is now an mqtt plugin for octoprint, so I will write up a guide how to use it that way soon!
I changed the rule a little bit, so that I dont get Errors anymore:
    var url = "http://xxx.xxx.xxx.xxx/api/job?apikey=YYYYYYYYYYYYYYYYYYYYYY"
    var url = 'http://xxx.xxx.xxx.xxx/api/system/commands/core/' + OctoprintSystemCommand.state + '?apikey=YYYYYYYYYYYYYYYYYYYYYY'
rule "Octoprint Status"
	Time cron "0 0/2 * 1/1 * ? *"
var String JOctoprintPrinterState = sendHttpGetRequest("http://xxx.xxx.xxx.xxx/api/connection?apikey=YYYYYYYYYYYYYYYYYYYYYY")
   var VOctoprintPrinterState = transform("JSONPATH", "$.current.state", JOctoprintPrinterState)
   OctoprintPrinterState.postUpdate(VOctoprintPrinterState)
   var VOctoprintPrinterProfile = transform("JSONPATH", "$.current.printerProfile", JOctoprintPrinterState)
   OctoprintPrinterProfile.postUpdate(VOctoprintPrinterProfile)
	if (VOctoprintPrinterState != "Closed")
		if (VOctoprintPrinterState == "Printing")
			var String JOctoprintJob = sendHttpGetRequest("http://xxx.xxx.xxx.xxx/api/job?apikey=YYYYYYYYYYYYYYYYYYYYYY")
			var VOctoprintJobEstimatedPrintTime = transform("JSONPATH", "$.progress.printTimeLeft", JOctoprintJob)
			OctoprintJobEstimatedPrintTime.postUpdate(VOctoprintJobEstimatedPrintTime)
			var VOctoprintJobFileName = transform("JSONPATH", "$.job.file.name", JOctoprintJob)
			OctoprintJobFileName.postUpdate(VOctoprintJobFileName)
			var VOctoprintJobProgressCompletion = transform("JSONPATH", "$.progress.completion", JOctoprintJob)
			OctoprintJobProgressCompletion.postUpdate(VOctoprintJobProgressCompletion)
			var VOctoprintJobPrintTimeLeft = transform("JSONPATH", "$.progress.printTime", JOctoprintJob)
			OctoprintJobPrintTimeLeft.postUpdate(VOctoprintJobPrintTimeLeft)
		var String JOctoprintPrinter = sendHttpGetRequest("http://xxx.xxx.xxx.xxx/api/printer?apikey=YYYYYYYYYYYYYYYYYYYYYY")
			var VOctoprintPrinterPrintingState = transform("JSONPATH", "$.state.text", JOctoprintPrinter)
			OctoprintPrinterPrintingState.postUpdate(VOctoprintPrinterPrintingState)
			var VOctoprintPrinterHotEndTemp = transform("JSONPATH", "$.temperature.tool0.actual", JOctoprintPrinter)
			OctoprintPrinterHotEndTemp.postUpdate(VOctoprintPrinterHotEndTemp)
			var VOctoprintPrinterHotEndTempTarget = transform("JSONPATH", "$.temperature.tool0.target", JOctoprintPrinter)
			OctoprintPrinterHotEndTempTarget.postUpdate(VOctoprintPrinterHotEndTempTarget)
			var VOctoprintPrinterBedTemp = transform("JSONPATH", "$.temperature.bed.actual", JOctoprintPrinter)
			OctoprintPrinterBedTemp.postUpdate(VOctoprintPrinterBedTemp)
			var VOctoprintPrinterBedTempTarget = transform("JSONPATH", "$.temperature.bed.actual", JOctoprintPrinter)
			OctoprintPrinterBedTempTarget.postUpdate(VOctoprintPrinterBedTempTarget)
I am getting a lot of the following messages:
    2019-11-19 08:27:51.241 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation 'JSONPATH($.temperature.tool0.target)' threw an exception. [response={
  "sd": {
    "ready": false
  "state": {
    "flags": {
      "cancelling": false,
      "closedOrError": false,
      "error": false,
      "finishing": false,
      "operational": true,
      "paused": false,
      "pausing": false,
      "printing": false,
      "ready": true,
      "resuming": false,
      "sdReady": false
    "text": "Operational"
  "temperature": {
    "bed": {
      "actual": null,
      "offset": 0,
      "target": 0.0
    2019-11-19 08:27:51.504 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation 'JSONPATH($.temperature.tool0.actual)' threw an exception. [response={
    2019-11-19 08:28:52.146 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation 'JSONPATH($.temperature.tool0.target)' threw an exception. [response={
    2019-11-19 08:28:52.401 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation 'JSONPATH($.temperature.tool0.actual)' threw an exception. [response={
    2019-11-19 08:29:53.019 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation 'JSONPATH($.temperature.tool0.target)' threw an exception. [response={
    2019-11-19 08:29:53.272 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation 'JSONPATH($.temperature.tool0.actual)' threw an exception. [response={
    2019-11-19 08:30:53.960 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation 'JSONPATH($.temperature.tool0.target)' threw an exception. [response={
    2019-11-19 08:30:54.242 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation 'JSONPATH($.temperature.tool0.actual)' threw an exception. [response={
I have removed the responses since it was too big to post. I have OctoPrint Version 1.3.12
For OH3 with the new http binding:
Items
// Octoprint
String OctoprintPrinterState			"State [%s]"					                				(gOctoprint)	{channel="http:url:printer-connection:current_state"}
String OctoprintPrinterProfile			"Profile [%s]"					                                (gOctoprint)	{channel="http:url:printer-connection:printerProfile"}
Number OctoprintJobEstimatedPrintTime	"Estimated Print Time [%.0f s]"	                <time>          (gOctoprint)	{channel="http:url:printer-job:estimatedPrintTime"}
String OctoprintJobFileName				"Filename [%s]"					                <text>          (gOctoprint)	{channel="http:url:printer-job:filename"}
Number OctoprintJobProgressCompletion	"Completion [%.0f %%]"					        <battery>       (gOctoprint)	{channel="http:url:printer-job:progress"}
Number OctoprintJobPrintTime			"Time Printed [%.0f s]"			                <time>	        (gOctoprint)	{channel="http:url:printer-job:printTime"}
Number OctoprintJobPrintTimeLeft		"Time Left [%.0f s]"			                <time>	        (gOctoprint)	{channel="http:url:printer-job:printTimeLeft"}
String OctoprintPrinterPrintingState    "Printing State [%s]"								    		(gOctoprint)    {channel="http:url:printer-info:state"}
Number OctoprintPrinterHotEndTemp		"Nozzle temp [%.1f °C]"		                    <temperature>	(gOctoprint)	{channel="http:url:printer-info:temperature_bed_actual"}
Number OctoprintPrinterHotEndTempTarget	"Nozzle target [%.1f °C]"	                    <temperature>	(gOctoprint)	{channel="http:url:printer-info:temperature_bed_target"}
Number OctoprintPrinterBedTemp			"Bed temp [%.1f °C]"		                    <temperature>	(gOctoprint)	{channel="http:url:printer-info:temperature_hotend_actual"}
Number OctoprintPrinterBedTempTarget	"Bed target [%.1f °C]"							<temperature>	(gOctoprint)	{channel="http:url:printer-info:temperature_hotend_target"}
http.things
Thing http:url:printer-connection "3D Printer Connection" [ baseURL="http://octopi.yourdomain/api/connection?apikey=YOURAPIKEY", refresh=60] {
    Channels:
        Type string : current_state "Current State" [ stateTransformation="JSONPATH:$.current.state" ]
		Type string : printerProfile "Printer Profile" [ stateTransformation="JSONPATH:$.current.printerProfile" ]
Thing http:url:printer-job "3D Printer Print Job" [ baseURL="http://octopi.yourdomain/api/job?apikey=YOURAPIKEY", refresh=60] {
    Channels:
        Type number : estimatedPrintTime "Estimated Print Time" [ stateTransformation="JSONPATH:$.job.estimatedPrintTime" ]
		Type string : filename "Filename" [ stateTransformation="JSONPATH:$.job.file.name" ]
		Type number : filesize "Filesize" [ stateTransformation="JSONPATH:$.job.file.size" ]
		Type number : progress "Progress" [ stateTransformation="JSONPATH:$.progress.completion" ]
		Type number : filepos "Printed" [ stateTransformation="JSONPATH:$.progress.filepos" ]
		Type number : printTime "Time Printed" [ stateTransformation="JSONPATH:$.progress.printTime" ]
		Type number : printTimeLeft "Time Left" [ stateTransformation="JSONPATH:$.progress.printTimeLeft" ]
Thing http:url:printer-info "3D Printer Info" [ baseURL="http://octopi.yourdomain/api/printer?apikey=YOURAPIKEY", refresh=60] {
    Channels:
        Type string : state "Printing State" [ stateTransformation="JSONPATH:$.state.text" ]
		Type number : temperature_bed_actual "Temperature Bed Actual" [ stateTransformation="JSONPATH:$.temperature.tool0.actual" ]
		Type number : temperature_bed_target "Temperature Bed Target" [ stateTransformation="JSONPATH:$.temperature.tool0.target" ]
		Type number : temperature_hotend_actual "Temperature Hotend Actual" [ stateTransformation="JSONPATH:$.temperature.bed.actual" ]
		Type number : temperature_hotend_target "Temperature Hotend Target" [ stateTransformation="JSONPATH:$.temperature.bed.target" ]
The Rule #2 (Time Left String) doesnt matter with OpenHAB 3. Can someone define the Rule #2 fĂźr Openhab 3?
Thanks, Cool!
I think there is a small typo in the item file:
should be
Your absolutly right!
Didn’t notice it till yesterday, forgot to update it here, will do now, thanks!
Does anyone have a OH3 widget displaying the webcam feed from Octoprint? I haven’t been able to get the right combination of things to make it work. I’m not doing much with video in my automations right now…
