HI Vlad, Not sure about the 21degrees. It could be correct as it might be the temperature while the water was heating up. I looked at the log files again and could only find the status going from on to off, nothing else.
All the other devices are working fine, just the kettle stays offline. There’s a setting that allows you to keep your water warm for a set period of time which you then monitor in the iphone app. So when I took the screenshot it was set for 80 degrees for 1 hour.
Here’s the screenshot for the scale, let me know if it’s too small.
