Hi!
congratulation for reaching this state!
I tried installing your binding, getting following errors:
2018-01-09 21:21:08.565 [WARN ] [ace.internal.BindingExtensionHandler] - Installed bundle, but failed to start it: Could not resolve module: org.sputnikdev.org.eclipse.smarthome.binding.bluetooth.transport.bluegiga [239]
Unresolved requirement: Import-Package: org.sputnikdev.bluetooth
2018-01-09 21:21:10.341 [WARN ] [ace.internal.BindingExtensionHandler] - Installed bundle, but failed to start it: Could not resolve module: org.sputnikdev.org.eclipse.smarthome.binding.bluetooth.transport.tinyb [240]
2018-01-09 21:21:30.395 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "DFU Control Point" does not have either Value or Fields tags, therefore reading the such characteristic will not be possible.
2018-01-09 21:21:30.425 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "DFU Packet" does not have either Value or Fields tags, therefore reading the such characteristic will not be possible.
2018-01-09 21:21:30.965 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "Bond Management Control Point" is not valid neither for read nor for write operation due to unfulfilled requirements: read ([Conditional]) write ([Conditional]).
2018-01-09 21:21:31.117 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "CGM Measurement" is not valid neither for read nor for write operation due to unfulfilled requirements: read ([C3]) write ([C3, C1, C2]).
2018-01-09 21:21:31.136 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "CGM Session Run Time" is not valid neither for read nor for write operation due to unfulfilled requirements: read ([C1]) write ([C1]).
2018-01-09 21:21:31.155 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "CGM Session Start Time" is not valid neither for read nor for write operation due to unfulfilled requirements: read ([C1]) write ([C1]).
2018-01-09 21:21:31.195 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "CGM Specific Ops Control Point" is not valid neither for read nor for write operation due to unfulfilled requirements: read ([C1]) write ([C1]).
2018-01-09 21:21:31.213 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "CGM Status" is not valid neither for read nor for write operation due to unfulfilled requirements: read ([C1]) write ([C1]).
2018-01-09 21:21:31.302 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "Cycling Power Control Point" is not valid neither for read nor for write operation due to unfulfilled requirements: read ([Optional, C1, C2]) write ([Optional, C1, C2]).
2018-01-09 21:21:31.381 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "Cycling Power Measurement" is not valid neither for read nor for write operation due to unfulfilled requirements: read ([C3, C4, C5, Optional, C1, C2]) write ([C3, C4, C5, Optional, C1, C2]).
2018-01-09 21:21:31.416 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "Cycling Power Vector" is not valid neither for read nor for write operation due to unfulfilled requirements: read ([Optional, C1, C2]) write ([Optional, C1, C2]).
2018-01-09 21:21:31.535 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "Descriptor Value Changed" does not have either Value or Fields tags, therefore reading the such characteristic will not be possible.
2018-01-09 21:21:32.333 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "LN Control Point" is not valid neither for read nor for write operation due to unfulfilled requirements: read ([Optional, C1, C2]) write ([Optional, C1, C2]).
2018-01-09 21:21:32.427 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "Location and Speed Characteristic" is not valid neither for read nor for write operation due to unfulfilled requirements: read ([Optional, C1]) write ([Optional, C1]).
2018-01-09 21:21:32.582 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "Navigation" is not valid neither for read nor for write operation due to unfulfilled requirements: read ([Optional]) write ([Optional]).
2018-01-09 21:21:32.612 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "Object Action Control Point" does not have either Value or Fields tags, therefore reading the such characteristic will not be possible.
2018-01-09 21:21:32.626 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "Object Changed" does not have either Value or Fields tags, therefore reading the such characteristic will not be possible.
2018-01-09 21:21:32.681 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "Object List Control Point" does not have either Value or Fields tags, therefore reading the such characteristic will not be possible.
2018-01-09 21:21:32.693 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "Object List Filter" does not have either Value or Fields tags, therefore reading the such characteristic will not be possible.
2018-01-09 21:21:32.721 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "Object Properties" does not have either Value or Fields tags, therefore reading the such characteristic will not be possible.
2018-01-09 21:21:32.762 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "OTS Feature" does not have either Value or Fields tags, therefore reading the such characteristic will not be possible.
2018-01-09 21:21:32.919 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "Position Quality" is not valid neither for read nor for write operation due to unfulfilled requirements: read ([Optional]) write ([Optional]).
2018-01-09 21:21:33.127 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "SC Control Point" is not valid neither for read nor for write operation due to unfulfilled requirements: read ([C3, C1, C2]) write ([C3, C1, C2]).
2018-01-09 21:21:33.266 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "TDS Control Point" does not have either Value or Fields tags, therefore reading the such characteristic will not be possible.
2018-01-09 21:21:33.570 [WARN ] [pec.BluetoothGattSpecificationReader] - Characteristic "User Control Point" does not have either Value or Fields tags, therefore reading the such characteristic will not be possible.
2018-01-09 21:21:37.052 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'bluetooth:adapter:B827EB9DF87C' to inbox.
2018-01-09 21:22:07.907 [WARN ] [.core.thing.binding.BaseThingHandler] - BaseThingHandler.initialize() will be removed soon, ThingStatus can be set manually via updateStatus(ThingStatus.ONLINE)
2018-01-09 21:22:08.039 [WARN ] [impl.AbstractBluetoothObjectGovernor] - Could not update governor state.
org.sputnikdev.bluetooth.manager.NotReadyException: Could not power adapter
at org.sputnikdev.bluetooth.manager.impl.AdapterGovernorImpl.updatePowered(AdapterGovernorImpl.java:218) ~[?:?]
at org.sputnikdev.bluetooth.manager.impl.AdapterGovernorImpl.update(AdapterGovernorImpl.java:65) ~[?:?]
at org.sputnikdev.bluetooth.manager.impl.AdapterGovernorImpl.update(AdapterGovernorImpl.java:42) ~[?:?]
at org.sputnikdev.bluetooth.manager.impl.AbstractBluetoothObjectGovernor.update(AbstractBluetoothObjectGovernor.java:160) ~[?:?]
at org.sputnikdev.bluetooth.manager.impl.AbstractBluetoothObjectGovernor.init(AbstractBluetoothObjectGovernor.java:150) ~[?:?]
at org.sputnikdev.bluetooth.manager.impl.BluetoothManagerImpl.lambda$null$4(BluetoothManagerImpl.java:236) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
sudo systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
Active: active (running) since Tue 2018-01-09 21:19:58 CET; 4min 19s ago
Docs: man:bluetoothd(8)
Main PID: 6856 (bluetoothd)
Status: "Running"
CGroup: /system.slice/bluetooth.service
└─6856 /usr/libexec/bluetooth/bluetoothd
Jan 09 21:19:58 openHABianPi bluetoothd[6856]: Bluetooth daemon 5.47
Jan 09 21:19:58 openHABianPi systemd[1]: Started Bluetooth service.
Jan 09 21:19:58 openHABianPi bluetoothd[6856]: Starting SDP server
Jan 09 21:19:58 openHABianPi bluetoothd[6856]: Bluetooth management interface 1.14 initialized
