Ok, then you have installed the official binding which is - in my opinion - a piece of Sh… or just a bad joke. I had exactly the same problems like you and anybody else on this forum. I don’t know why this binding is still presented as a featured binding on the Webpage as it does not work at all.
You need to install Eclipse Smart Home Marketplace (Addons - Misc) and then choose level ‘Alpha’ for displayed bindings in Configuration.
The correct binding should show up in paperUi like this:
OK i will try but before I install, end up wasting ages (I always do with anything openhab related) do you know if it will work with the built in Bluetooth on the RPI
I have installed the binding and setup with openhabs rpi bluetooth
tested with my mobile (found that usless like people said)
I cant find the bluetooth from my smartwatch too test how that behaves do you or does anyone else know what too do or know about blutooth on smartwatches?
Hi
I installed the binding yesterday evening and successfully saw some devices.
Today I am trying more seriously to connect, but when I try to set ConnectionControl to ON I get the following it just changes back to OFF after half a minute or so:
2019-02-05 19:59:01.310 [ome.event.ItemCommandEvent] - Item 'ScaleCH100_ConnectionControl' received command ON
2019-02-05 19:59:01.318 [nt.ItemStatePredictedEvent] - ScaleCH100_ConnectionControl predicted to become ON
2019-02-05 19:59:01.336 [vent.ItemStateChangedEvent] - ScaleCH100_ConnectionControl changed from OFF to ON
2019-02-05 19:59:05.800 [vent.ItemStateChangedEvent] - ScaleCH100_ConnectionControl changed from ON to OFF
2019-02-05 19:59:48.665 [ome.event.ItemCommandEvent] - Item 'ScaleCH100_ConnectionControl' received command ON
2019-02-05 19:59:48.676 [nt.ItemStatePredictedEvent] - ScaleCH100_ConnectionControl predicted to become ON
2019-02-05 19:59:48.689 [vent.ItemStateChangedEvent] - ScaleCH100_ConnectionControl changed from OFF to ON
2019-02-05 20:00:05.794 [vent.ItemStateChangedEvent] - ScaleCH100_ConnectionControl changed from ON to OFF
The same happens with another device I tries. Must be some noob mistake; I would appreciate any help.
I use the Bluetooth adapter build into my Raspberry and I’m on Bluez 5.43 (got that with Openhabian).
Ok, did a reboot, and now it can stay with ConnectionControl ON.
However, trying to connect to my Huwei AN100/CN100 I get the following:
2019-02-05 20:39:48.036 [vent.ItemStateChangedEvent] - ScaleCH100_Connected changed from OFF to ON
2019-02-05 20:39:48.749 [ERROR] [.manager.transport.tinyb.TinyBDevice] - Services resolved notification execution error
at org.sputnikdev.bluetooth.gattparser.spec.BluetoothGattSpecificationReader.validate(BluetoothGattSpecificationReader.java:304) ~[?:?]
at org.sputnikdev.bluetooth.gattparser.spec.BluetoothGattSpecificationReader.addCharacteristic(BluetoothGattSpecificationReader.java:294) ~[?:?]
at org.sputnikdev.bluetooth.gattparser.spec.BluetoothGattSpecificationReader.getCharacteristicByUUID(BluetoothGattSpecificationReader.java:131) ~[?:?]
at org.sputnikdev.bluetooth.gattparser.BluetoothGattParser.isKnownCharacteristic(BluetoothGattParser.java:86) ~[?:?]
at org.sputnikdev.esh.binding.bluetooth.handler.AutomaticPinCodeAuthProvider.lambda$discoverPinCodeCharacteristic$1(AutomaticPinCodeAuthProvider.java:64) ~[?:?]
at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:174) ~[?:?]
at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1382) ~[?:?]
at java.util.stream.ReferencePipeline$Head.forEach(ReferencePipeline.java:580) ~[?:?]
at java.util.stream.ReferencePipeline$7$1.accept(ReferencePipeline.java:270) ~[?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481) ~[?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471) ~[?:?]
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708) ~[?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]
at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:499) ~[?:?]
at org.sputnikdev.esh.binding.bluetooth.handler.AutomaticPinCodeAuthProvider.discoverPinCodeCharacteristic(AutomaticPinCodeAuthProvider.java:65) ~[?:?]
at org.sputnikdev.esh.binding.bluetooth.handler.AutomaticPinCodeAuthProvider.authenticate(AutomaticPinCodeAuthProvider.java:41) ~[?:?]
at org.sputnikdev.bluetooth.manager.impl.DeviceGovernorImpl.authenticate(DeviceGovernorImpl.java:833) ~[?:?]
at org.sputnikdev.bluetooth.manager.impl.DeviceGovernorImpl.access$800(DeviceGovernorImpl.java:63) ~[?:?]
at org.sputnikdev.bluetooth.manager.impl.DeviceGovernorImpl$ServicesResolvedNotification.notify(DeviceGovernorImpl.java:817) ~[?:?]
at org.sputnikdev.bluetooth.manager.impl.DeviceGovernorImpl$ServicesResolvedNotification.notify(DeviceGovernorImpl.java:807) ~[?:?]
at org.sputnikdev.bluetooth.manager.transport.tinyb.TinyBDevice.lambda$null$6(TinyBDevice.java:203) ~[?:?]
at org.sputnikdev.bluetooth.manager.transport.tinyb.TinyBFactory.lambda$notifySafely$0(TinyBFactory.java:237) ~[?:?]
If I connect to the CH100 with the BLE Scanner app I actually see some apparently nice GATT fields, so I was hoping to get it to work i OpenHAB. I am still on Bluez 5.43. Again, any help would be appreciated.
The error you see is a bug apparently. This happens when it tries to “parse” gatt characteristics, obviously your scales is not supported as nobody added GATT specs for your scales yet (you are welcome do so it and update this repo: https://github.com/sputnikdev/bluetooth-gatt-parser)
Having said that, you should be able to get binary data from your device. Set this setting to do so:
Please enable binary only discovery and report what channels you get in that ticket on github. We will try to come up with some gatt specs for your scales so you should be able to get some meaningful data.
Wow, that is better support than for any software I have ever used before
I have commented on the github issue and will move the communication over there - just wanted to say “wow” here in this tread…
Its the actual device/item itself as you can see from the screenshot of my timeline there were times when the device went off when it was in fact on
there are blips all over the timeline but my phone has been on with the beacon app running since i spoke too you last night
There’s a gap over 12 mins long where it says the device is off then a long period of 3 1/2 hours where it correctly reports on and then lots of jitter later on
