As it was expected, I’ve encountered a new problem. This time is with the Arduino IDE sketch code in my NodeMCU. I want to control 4 relays. However, it doesn’t matter the switch I activate in Openhab2, it always activates the first relay.
It seems that the problem is with the payload. Here’s a part of my code.
Definition of gpios:
//GPIOS
const int piscinaFILTRACION = 5;
const int piscinaLUCES = 4;
const int piscinaCHORRO = 0;
const int piscinaJACUZZI = 2;
Topics:
//topic to subscribe
char* filtracionTopic = "/dva/piscina/filtracion";
char* lucesTopic = "/dva/piscina/luces";
char* chorroTopic = "/dva/piscina/chorro";
char* jacuzziTopic = "/dva/piscina/jacuzzi";
//topic to publish to confirm that the light has been turned on for the python script to log
char* filtracionConfirmTopic = "/dva/piscina/filtracionconfirm";
char* lucesConfirmTopic = "/dva/piscina/lucesconfirm";
char* chorroConfirmTopic = "/dva/piscina/choroconfirm";
char* jacuzziConfirmTopic = "/dva/piscina/jacuzziconfirm";
//MQTT callback
void callback(char* topic, byte* payload, unsigned int length) {
char p0 = (char)payload[0];
char p1 = (char)payload[1];
char p2 = (char)payload[2];
char p3 = (char)payload[3];
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
//convert topic to string to make it easier to work with
String topicStr = topic;
//Print out some debugging info
Serial.println("Callback update.");
Serial.print("Topic: ");
Serial.println(topicStr);
//turn the light on if the payload is '1' and publish to the confirmation topic so the python script can log it
if(p0 == '1'){
digitalWrite(piscinaFILTRACION, HIGH);
client.publish(filtracionConfirmTopic, "On");
else if (p0 == '0'){
digitalWrite(piscinaFILTRACION, LOW);
client.publish(filtracionConfirmTopic, "Off");
if(p1 == '1'){
digitalWrite(piscinaLUCES, HIGH);
client.publish(lucesConfirmTopic, "On");
else if (p1 == '0'){
digitalWrite(piscinaLUCES, LOW);
client.publish(lucesConfirmTopic, "Off");
if(p2 == '1'){
digitalWrite(piscinaCHORRO, HIGH);
client.publish(chorroConfirmTopic, "On");
else if (p2 == '0'){
digitalWrite(piscinaCHORRO, LOW);
client.publish(chorroConfirmTopic, "Off");
if(p3 == '1'){
digitalWrite(piscinaJACUZZI, HIGH);
client.publish(jacuzziConfirmTopic, "On");
else if (p3 == '0'){
digitalWrite(piscinaJACUZZI, LOW);
client.publish(jacuzziConfirmTopic, "Off");
Could you please check the code?
