I am using openHAB version: 3.1.0 Release Build, on a aspberry Pi 4B with OpenHABian (working fine since months… well… more or less )
I have found one “item” (a light) that I cannot to edit via the OH administration UI. When I try to do so, I get a blank page. Behind that page, I guess that some piece of code is executed and fails; I can indeed systematically see the “stack overflow error” message here under in the logs, after each attempt to edit the item:
2022-01-04 17:42:20.843 [ERROR] [internal.JSONResponseExceptionMapper] - Unexpected exception occurred while processing REST request.
java.util.regex.PatternSyntaxException: Stack overflow during pattern compilation near index 0
[\w-]*
at java.util.regex.Pattern.error(Pattern.java:2027) ~[?:?]
at java.util.regex.Pattern.<init>(Pattern.java:1430) ~[?:?]
at java.util.regex.Pattern.compile(Pattern.java:1068) ~[?:?]
at java.util.regex.Pattern.matches(Pattern.java:1173) ~[?:?]
at java.lang.String.matches(String.java:2024) ~[?:?]
at org.openhab.core.common.AbstractUID.validateSegment(AbstractUID.java:97) ~[?:?]
at org.openhab.core.common.AbstractUID.<init>(AbstractUID.java:76) ~[?:?]
at org.openhab.core.common.AbstractUID.<init>(AbstractUID.java:59) ~[?:?]
at org.openhab.core.thing.UID.<init>(UID.java:57) ~[?:?]
at org.openhab.core.thing.ThingUID.<init>(ThingUID.java:139) ~[?:?]
at org.openhab.core.thing.ChannelUID.getThingUID(ChannelUID.java:150) ~[?:?]
at org.openhab.core.thing.internal.ThingRegistryImpl.getChannel(ThingRegistryImpl.java:80) ~[?:?]
at org.openhab.core.thing.internal.ChannelStateDescriptionProvider.getStateDescription(ChannelStateDescriptionProvider.java:97) ~[?:?]
at org.openhab.core.thing.internal.ChannelStateDescriptionProvider.getStateDescriptionFragment(ChannelStateDescriptionProvider.java:86) ~[?:?]
at org.openhab.core.internal.service.StateDescriptionServiceImpl.getMergedStateDescriptionFragments(StateDescriptionServiceImpl.java:71) ~[?:?]
at org.openhab.core.internal.service.StateDescriptionServiceImpl.getStateDescription(StateDescriptionServiceImpl.java:63) ~[?:?]
at org.openhab.core.items.GenericItem.getStateDescription(GenericItem.java:409) ~[?:?]
at org.openhab.core.library.items.NumberItem.getStateDescription(NumberItem.java:85) ~[?:?]
at org.openhab.core.io.rest.core.item.EnrichedItemDTOMapper.considerTransformation(EnrichedItemDTOMapper.java:126) ~[?:?]
at org.openhab.core.io.rest.core.item.EnrichedItemDTOMapper.map(EnrichedItemDTOMapper.java:68) ~[?:?]
The last line repeats many times.
How could I delete this “probably corrupted” item (The remove button is assumed to be on the blank page ) ? I would like to recreate this item from scratch as it was probably messed up (most items were created for OpenHAB 1.x via text files, upgraded to OH 2 and finally imported in OH 3).
Thx in adv for your guidance !
V.
