Thanks Justin. That is actually really nice.
I could not get the location. Is that because the item related to equipment instead of directly within a location?
Yes. The semantic tags do not propagate down the hierarchy so hasLocation
only works for equipment not points.
In some cases you may want to add some points to the location group directly, in addition to the equipment. For instance adding a temperature measurement to a room location, because it represents the temperature in the room.
Am I going mad? I can’t seem to search more than one itemTag at a time.
I type itemTags: Smartphone
and all Smartphone tagged items are found. But the moment I add a second term I get 0 results itemTags: Smartphone,Smartwatch
All of the examples above that use more than one term just seperate with a comma, but this just isn’t working for me
The array in itemTags
is treated as AND. You cannot search for Smartphone OR Smartwatch
, but you can search for Switch AND Light
or Door AND Status
Ahhh…
secrets.
Wonder why this simple info isn’t in the docs?
Is there a way to do OR?
This isn’t really a choice of the UI design, it comes directly from the API; that’s how the API call to fetch items works. That said, this question does come up once in a blue moon and may be worth adding to the docs.
Yes, but…
You can get the repeater to return a complete list of all the items and then use the repeater filter
property to get only tag A OR tag B. The ‘but’ here is that that’s going to be somewhat process intensive and if you have to do it more than a few times on a UI page, you’re definitely going to see a slow down.
The better solution here is just to add another custom tag to these items, PersonalDevice
or some such and then use that in the repeater. Yeah, it’s one small extra step, but it results in more direct control of which items your repeater is delivering and, although I don’t know your system, I’m going to guess that these items don’t change or get added and removed often enough for this to be a particular hardship from an administrative standpoint.
Thanks. You always give very good answers.
No idea if I can post it here, but for some reason my icons are not dynamic anymore in my oh-repeater
Code:
- component: oh-repeater
for: item
fragement: true
groupItem: Blinds
sourceType: itemsInGroup
slots:
default:
- component: oh-rollershutter-item
icon: oh:rollershutter
item: =loop.item.name
title: =loop.item.label
And this as result:
Which looks good enough except that my icon is not showing the correct state, for example if I check it in the Overview>Location it looks like this:
here it is clearly closed, tried finding on the forums why it does this but can’t find what im doing wrong.
When using an OH icon there is a second parameter to indicate if the icon is dynamic or not (in the UI it’s called “Icon depends on state” but I’m not sure what the actual name of the field is. From a quick scan of the reference docs it looks like it might just be state
For OH icons the state
parameter lets you manually set a state which the icon will respond to (which can of course just be set to the dynamic state of an item).
For the family of list item components, such as the oh-rollershutter-item
the parameter to use is iconUseState
which you just set to true
if you want the icon to respond to the state of the item that the component is bound to.
when i add this widget and save the page, the widget gets reset?
Hello Rick,
I am trying to make a generic selection widget and I am having a problem when passing an props.item to the repeater.
Maybe you have an idea.
This is what I want to achieve:
The radio stations are number items:
String SonosPlay3Essen_Tuneinstationid (gSonos) {
channel="sonos:PLAY3:RINCON_5CAAFD5AB44801400:tuneinstationid",
stateDescription=""[
pattern="%d",
options="
15439=Radio Aargovia,
17465=SRF1,
24862=SRF3,
57881=Radio Fantasy,
96745=Antenne Bayern Chillout,
214040=Charivari LOUNGE,
2591=SomaFM-Groove-Salad,
42828=Deutschlandfunk,
120806=Deutschlandfunk Nova,
42824=Antenne Bayern
The widget code for the button is (the item is hard coded to SonosPlay3Bad_Tuneinstationid):
for: selection
fragment: true
in:
- icon: f7:hifispeaker
item: SonosPlay3Bad_Tuneinstationid
sourceType: array
slots:
default:
- component: f7-col
slots:
default:
- component: oh-list
slots:
default:
- component: oh-list-item
after: =items[loop.selection.item].displayState
icon: =loop.selection.icon
iconColor: default
popupOpen: =".selectionPopupBad_"+loop.selection_idx
smartSelect: true
style:
border: 1px solid lightgray
border-radius: 5px
title: =loop.selection.title
and for the popup window:
- component: f7-popup
class: ="selectionPopupBad_"+loop.selection_idx
slots:
default:
- component: f7-page
slots:
default:
- component: f7-navbar
style:
position: sticky
slots:
left:
- component: oh-link
iconAurora: f7:arrow_left
iconIos: f7:arrow_left
iconMd: material:arrow_back
popup-close: true
- component: f7-list
virtualList: true
slots:
default:
for: option
fragment: true
itemOptions: =loop.selection.item
sourceType: itemStateOptions
slots:
default:
action: command
actionCommand: =loop.option.value
actionFeedback: ='{ "text":"You selected <b>' + loop.option.label + '</b><br>Sending command <b>' + loop.option.value + "to item " + loop.selection.item + '</b>", "position":"center","icon":"<i style=\\"color:green\\" class=\\"f7-icons\\">checkmark_alt</i>","closeButton":true }'
actionItem: =loop.selection.item
checked: "=loop.option.value === items[loop.selection.item].state ? true : false"
noChevron: true
popupClose: true
radio: true
title: =loop.option.label
Right now I have 4 selection widgets but to clean up the code I want to have one for all 4 items.
The problem is here:
when using this:
item: =items[props.ItemTuneInStationId]
It doesn’t work. Here ItemTuneInStationId is given by the widget configuration
Unfortunately the extent of my knowledge on UI widgets is on display above. I’ve not really messed with options before except very basically in a List Item Widget and even then I didn’t do much more than see that it works, but that was a totally different base widget and use case.
I don’t really have any great ideas but suggest you post a new thread so people who are better at widgets than I am might see it.
The only general thing I can think of is I often need to put expressions into double quotes so you might try
item: "=items[props.ItemTuneInStationId]"
Here you are setting the value of item
to a string of the item name that you want, which is correct.
to an object with state
, displayState
, and type
(depending on OH version) keys. This is not the same thing.
is already a string. You don’t need to do anything to it just pass it directly to the item
property.
item: =props.ItemTuneInStationId
Justin this was it, thank you for the hint.
I have now a generic selection widget:
uid: select
tags:
- Custom
props:
parameters:
- context: item
description: Selection Item with State Descirption
label: Selection Item
required: true
type: TEXT
- context: text
label: Icon
required: false
type: TEXT
parameterGroups: []
timestamp: Sep 15, 2023, 11:35:07 PM
for: selection
fragment: true
in:
- icon: =props.icon
item: =props.itemSelect
sourceType: array
slots:
default:
- component: f7-col
slots:
default:
slots:
default:
iconColor: default
popupOpen: =".selectionPopup_" + props.itemSelect + loop.selection_idx
smartSelect: true
style:
border-radius: 5px
margin-left: 10px
margin-right: 10px
margin-top: 10px
class: ="selectionPopup_" + props.itemSelect + loop.selection_idx
slots:
default:
slots:
default:
style:
position: sticky
slots:
left:
popup-close: true
virtualList: true
slots:
default:
for: option
fragment: true
slots:
default:
action: command
actionFeedback: ='{ "text":"You selected <b>' + loop.option.label + '</b><br>Sending command <b>' + loop.option.value + '</b> to item", "position":"center","icon":"<i style=\\"color:green\\" class=\\"f7-icons\\">checkmark_alt</i>","closeButton":true }'
noChevron: true
popupClose: true
radio: true
which can than be included in other widgets, e.g.:
uid: radiostation-select
tags: []
props:
parameters:
- label: title
required: false
type: TEXT
- context: item
description: Sonos tuneinstationid item
label: ItemTuneInStationId
required: true
type: TEXT
parameterGroups: []
timestamp: Sep 15, 2023, 11:57:47 PM
component: f7-card
style:
box-shadow: 5px 5px 10px 1px rgba(0,0,0,0.1)
height: 110px
noShadow: false
width: 350px
title: =props.vTitel
slots:
default:
- component: widget:select
itemSelect: =props.ItemTuneInStationId
Resulting in:
So the code is now much better than before as I had the selection code in many widgets.
I tried to extend the example from @rlkoshak at the beginning of the thread with the switch for the group. No matter how I try to set it up, the outcome always looks weird. any ideas ?
uid: all_lights
tags:
- card
- lights
props:
parameters:
- description: A text prop
label: Card title
required: false
type: TEXT
- context: item
description: An item to control
label: Item
required: false
type: TEXT
parameterGroups: []
timestamp: Jan 22, 2024, 5:34:39 PM
component: f7-card
title: =props.title
slots:
default:
- component: oh-toggle-item
item: =props.lightgroup
icon: f7:lightbulb
title: =props.lightgroup
slots:
default:
for: item
groupItem: =props.lightgroup
fragment: true
slots:
default:
icon: f7:lightbulb
iconColor: '=(items[loop.item.name].state == "ON") ? "yellow" : "gray"'
color: '=(items[loop.item.name].state == "ON") ? "green" : "gray"'
It will help you to understand if you dig a little deeper into the different types of components:
Especially relevant is this line:
- List Item: a component placed inside a list type container meant only to be displayed as part of a list and which will not display properly on its own (e.g.,
oh-slider-item
Thanks @JustinG this worked. Thus I am still trying to find out why I can access .state but not .displayState of items[props.lightgroup] in the title
uid: all_lights
tags:
- card
- lights
props:
parameters:
label: Card title
required: false
type: TEXT
- context: item
label: Item
required: false
type: TEXT
parameterGroups: []
component: f7-card
title: =props.title
slots:
default:
virtualList: true
slots:
default:
icon: f7:lightbulb
title: =items[props.lightgroup].state
iconColor: '=(items[props.lightgroup].state == "ON") ? "yellow" : "gray"'
label: as
color: '=(items[props.lightgroup].state == "ON") ? "green" : "gray"'
for: item
fragment: true
slots:
default:
icon: f7:lightbulb
