Just a short question, would it be a big work for someone to rewrite (rework) the code, to work directly with OpenHAB?
Or if I buy the components, make the small PCB and connect it to my OpenHAB through MQTT it will work?
What I like in this is that you can communicate with your DSC alarm using components which cost 10 times less then the, lets say… official ones.
I’ve managed to upload HomeAssistant-MQTT on my ESP8266. It is connected to MQTT of Openhab (and also to my DSC alarm), but I don’t think the syntax I’m trying to use works…
Any ideas how to move on, how can I check this zone state?
where (in which topic) does the ESP code publish Zone states?
You are currently using an inbound definition in your MQTT bound item that processes commands.
If you want status updates, identify the proper topic(s) and use one :state:default (instead of :command:ON:0)
it seems that the payload is 1 for ON and the topic is dsc/Get/Zone3
so the example above (with state:default) should work (I think that he won’t need a MAP xform)
