Hi
thank you for your answer
I have tested with another program for android. It is the same.
The problem is coming when the OH2 service is active. When it is inactive all work just fine.
Now I tested that you suggested - It is the same.
When I send one message (for example: Topic: Tk1, message: 25) from wherever, the openhab start sending messages.
I’m sure that the problem is in OH2, broker or in my configuration of OH2.
I think the arduino and the MQTT programs work fine, because I using them since a long time.
I forgot to post my items file:
Group heating (All)
Group irrigation (All)
//Group h_temperaturs (heating)
//Group h_pumps (heating)
//Group h_valves (heating)
//Group h_burners (heating)
Group sunheat (All)
Group boiler (ALL)
Group Heating_chart(ALL)
Group Temp_termostat_chart (Heating_chart)
Group RoomTemperatures(ALL)
Group:Switch:OR(ON, OFF) manual "всички[(%d)]"
Number Heating_chart_Period "Период"
Number Temp_termostat_Period "Период"
Group Boiler_chart (Heating_chart)
Number Boiler_chart_Period "Период"
Group colector_chart (Heating_chart)
Number colector_chart_Period "Период"
Group Heating_controls (Heating_chart)
Number Heating_state "Отопление" <inverter> (heating) {mqtt=">[mosquitto:Heating_state:command:*:default],<[mosquitto:Heating_state_stat:state:default]"}
Number termostatSettings "Използване на термостат" <heating> (heating){mqtt=">[mosquitto:termostatSettings:command:*:default],<[mosquitto:termostatSettings_stat:state:default]"}
Number termostat "Състояние термостат [%s]" <heating> (heating) {mqtt=">[mosquitto:termostat:command:*:default],<[mosquitto:termostat:state:default]"}
Number THeatingMod "Температура на водата [%.1f °C]" <radiator> (heating) {mqtt=">[mosquitto:THeatingMod:command:*:default],<[mosquitto:THeatingMod_stat:state:default]"}
Number THeatingMax "Макс. t° за отопление [%.1f °C]" <hot> (heating) {mqtt=">[mosquitto:THeatingMax:command:*:default],<[mosquitto:THeatingMax_stat:state:default]"}
Number THeatingMin "Мин. t° за отопление [%.1f °C]" <cold> (heating) {mqtt=">[mosquitto:THeatingMin:command:*:default],<[mosquitto:THeatingMin_stat:state:default]"}
Number boiler_state "бойлер" <boilera> (boiler) {mqtt=">[mosquitto:boiler_state:command:*:default],<[mosquitto:boiler_state_stat:state:default]"}
Number heater_control_t_on "t° за вкл. ел. нагревател [%.1f °C]" <smartheater> (boiler) {mqtt=">[mosquitto:heater_control_t_on:command:*:default],<[mosquitto:heater_control_t_on_stat:state:default]"}
Number heater_control_t_off "t° за изкл. ел. нагревател [%.1f °C]" <smartheater> (boiler) {mqtt=">[mosquitto:heater_control_t_off:command:*:default],<[mosquitto:heater_control_t_off_stat:state:default]"}
Number Tk1 "t° Колектор 1 (Тк1) [%.1f °C]" <temperature> (sunheat,Boiler_chart,colector_chart){mqtt="<[mosquitto:Tk1:state:default]"}
Number Tk2 "t° Колектор 2 (Тк2) [%.1f °C]" <temperature> (sunheat,Boiler_chart,colector_chart){mqtt="<[mosquitto:Tk2:state:default]"}
Number tbp "t° Серпентина Парно (tbp) [%.1f °C]" <temperature> (heating,Boiler_chart){mqtt="<[mosquitto:tbp:state:default]"}
Number tbc "t° Серпентина Колектор (tbc) [%.1f °C]" <temperature> (sunheat,Boiler_chart,colector_chart){mqtt="<[mosquitto:tbc:state:default]"}
Number tinst "t° инсталация 1(tinst) [%.1f °C]" <temperature> (heating,Heating_chart){mqtt="<[mosquitto:tinst:state:default]"}
Number tinst2 "t° инсталация 2 (tinst2) [%.1f °C]" <temperature> (heating,Heating_chart){mqtt="<[mosquitto:tinst2:state:default]"}
Number tout "t° изход п. котел (tout)[%.1f °C]" <hot> (heating,Heating_chart){mqtt="<[mosquitto:tout:state:default]"}
Number toutMaxSet "Макс. температура изход п. котел (tout)[%.1f °C]" <temperature> (heating,Heating_controls){mqtt=">[mosquitto:toutMaxSet:command:*:default],<[mosquitto:toutMaxSet_stat:state:default]"}
Number tin "t° вход п. котел (tin) [%.1f °C]" <cold> (heating,Heating_chart){mqtt="<[mosquitto:tin:state:default]"}
Number tinMinSet "Мин. Температура вход п. котел (tin) [%.1f °C]" <temperature> (heating,Heating_controls){mqtt=">[mosquitto:tinMinSet:command:*:default],<[mosquitto:tinMinSet_stat:state:default]"}
Number trec "t° рециркулация (trec)[%.1f °C]" <temperature> (heating,Heating_chart){mqtt="<[mosquitto:trec:state:default]"}
Number fourwayvalve "Четирипътен клапан [%s %%]" <four_way_Valvea> (heating,Heating_controls,Heating_chart)
Dimmer fourwayvalve_control "Четирипътен Клапан [%d %%]" <four_way_Valvea>{mqtt=">[mosquitto:fourwayvalve_control:command:*:default],<[mosquitto:fourwayvalve_control_stat:state:default]"}
Number treewayvalve "Трипътен клапан [%s]" <tree_way> (boiler)
Switch treewayvalve_control "Трипътен Клапан" <tree_way> (manual){mqtt=">[mosquitto:treewayvalve_control:command:*:default],<[mosquitto:treewayvalve_control_stat:state:default]"}
Number tb "t° бойлер (tb)[%.1f °C]" <temperature> (Boiler_chart){mqtt="<[mosquitto:tb:state:default]"}
Number tbMaxSet "t° бойлер задание (tbMaxSet)[%.1f °C]" <temperature> (Boiler_chart) {mqtt=">[mosquitto:tbMaxSet:command:*:default],<[mosquitto:tbMaxSet_stat:state:default]"}
Number pump1 "Помпа 1 [%s]" <pump> (heating,Heating_chart)// {mqtt="<[mosquitto:pump1:state:default]"}
Switch pump1_control "Помпа 1" <pump> (manual) {mqtt=">[mosquitto:pump1_control:command:*:default],<[mosquitto:pump1_control_stat:state:default]"}
Number pump2 "Помпа 2 [%s]" <pump> (heating,Heating_controls)
Switch pump2_control "Помпа 2" <pump> (manual) {mqtt=">[mosquitto:pump2_control:command:*:default],<[mosquitto:pump2_control_stat:state:default]"}
Number pumpColector "Помпа Колектор [%s]" <pump> (sunheat,Heating_controls)
Number deltaPumpColector "Делта Помпа Колектор [%s]" <pump> (sunheat){mqtt=">[mosquitto:deltaPumpColector:command:*:default],<[mosquitto:deltaPumpColector_stat:state:default]"}
Switch pumpColector_control "Помпа Колектор" <pump> (manual) {mqtt=">[mosquitto:pumpColector_control:command:*:default],<[mosquitto:pumpColector_control_stat:state:default]"}
Number infoburn "Разход горелка [%s кг/мин]" <fire> (heating){mqtt="<[mosquitto:infoburn:state:default]"}
Number infotank "Танкер [%s %%]" <sewerage> (heating){mqtt="<[mosquitto:infotank:state:default]"}
Number heater "Ел. нагревател [%s]" <smartheater> (heating,Heating_controls)
Switch heater_control "Ел. нагревател" <smartheater> (manual) {mqtt=">[mosquitto:heater_control:command:*:default],<[mosquitto:heater_control_stat:state:default]"}
Number burner2 "Котел ТГ [%s]" <fire> (heating,Heating_controls){mqtt=">[mosquitto:burner2:command:*:default],<[mosquitto:burner2:state:default]"}
Number burner "Горелка [%s]" <fire> (heating,Heating_controls){mqtt=">[mosquitto:burner_control:command:*:default],<[mosquitto:burner_control_stat:state:default]"}
Switch burner_control "Горелка" <fire> (manual) {mqtt=">[mosquitto:burner_control:command:*:default],<[mosquitto:burner_control_stat:state:default]"}
Number udate_state "Regresh MQTT" <refresh> (heating) {mqtt=">[mosquitto:udate_state:command:*:default]"}
Number hotStete "Режим на котела" <inverter> (heating) {mqtt=">[mosquitto:hotStete:command:*:default],<[mosquitto:hotStete_stat:state:default]"}
Switch calibrationFlagStart "калибровка клапaн" <four_way_Valvea> (heating) {mqtt=">[mosquitto:calibrationFlagStart:command:*:default],<[mosquitto:calibrationFlagStart_Stat:state:default]"}
Switch calibrationFlag"калибровка клапaн [%s]"<light> (heating) {mqtt=">[mosquitto:calibrationFlag:command:*:default],<[mosquitto:calibrationFlag_Stat:state:default]"}
Number boilerPriority "Приоритет бойлер [%s]"<priority> (heating) {mqtt=">[mosquitto:boilerPriority:command:*:default],<[mosquitto:boilerPriority_Stat:state:default]"}
Number tinstSet "Задание t инсталация [%s]" <temperature> (heating) {mqtt=">[mosquitto:tinstSet:command:*:default],<[mosquitto:tinstSet:state:default]"}
Number fourwayvalve_state "Реална позиция [%d %%]" <four_way_Valvea>(heating,Heating_chart){mqtt=">[mosquitto:fourwayvalve_state:command:*:default],<[mosquitto:fourwayvalve_state:state:default]"}
Number children_room_T "Температура [%.1f °C]" <temperature> (FF_Child,Temp_termostat_chart){mqtt="<[mosquitto:children_room_T:state:default]"}
Number children_room_T_Setpoint "Температура задание [%.1f °C]" <temperature> (All)
Number children_room_H "Влажност [%.1f %%]" <humidity> (FF_Child){mqtt="<[mosquitto:children_room_H:state:default]"}
//Switch termostat {mqtt=">[mosquitto:termostat:command:*:default],<[mosquitto:termostat:state:default]"}
Number treewayvalve_chart_flag "Трипътен клапан" <tree_way> (Heating_chart,Boiler_chart)
Number pumpColector_chart_flag "Помпа колектор" <pump> (colector_chart,Boiler_chart)
Number burner_chart_flag "Горелка пелети" <fire> (Heating_chart,Boiler_chart)
Number Termostat_chart_flag "Термостат" <smartheater> (Temp_termostat_chart)
Switch fileServer "Файл сървър" <computer>(network) { wol="192.168.100.255#00-18-F3-8A-DF-3F" }
Switch WaterSpliterContorller_Out1 "Кръг 1" <irrigation> (irrigation) {mqtt=">[mosquitto:Command_WaterSpliterContorller_Out1:command:*:default],<[mosquitto:Stat_WaterSpliterContorller_Out1:state:default]"}
Switch WaterSpliterContorller_Out2 "Кръг 2" <irrigation> (irrigation) {mqtt=">[mosquitto:Command_WaterSpliterContorller_Out2:command:*:default],<[mosquitto:Stat_WaterSpliterContorller_Out2:state:default]"}
Switch WaterSpliterContorller_Out3 "Кръг 3" <irrigation> (irrigation) {mqtt=">[mosquitto:Command_WaterSpliterContorller_Out3:command:*:default],<[mosquitto:Stat_WaterSpliterContorller_Out3:state:default]"}
Switch WaterSpliterContorller_Out4 "Кръг 4" <irrigation> (irrigation) {mqtt=">[mosquitto:Command_WaterSpliterContorller_Out4:command:*:default],<[mosquitto:Stat_WaterSpliterContorller_Out4:state:default]"}
Switch WaterSpliterContorller_Out5 "Кръг 5" <irrigation> (irrigation) {mqtt=">[mosquitto:Command_WaterSpliterContorller_Out5:command:*:default],<[mosquitto:Stat_WaterSpliterContorller_Out5:state:default]"}
