Hi I would like to understand the zwave messages a little better to better find reasons why stuff is not working.
If I look at the log below there is a switch (node5) which is
turned on and after some seconds turned off again…
am I correct if there is no “Receive Message” between this “on” and “off” … that means that the meter report was not sent by the device? hence if I would expect a meter report should be there there is NO issue with endpoint and command classes but way more likely with Config Params or Association if no “receive message” was watched at all?
Thanks for some infos
2016-09-07 18:23:36.318 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 05 03 25 03 FF 2D
2016-09-07 18:23:36.328 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-09-07 18:23:36.334 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 05 03 25 03 FF 2D
2016-09-07 18:23:36.339 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 05 03 25 03 FF 2D
2016-09-07 18:23:36.344 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 03 25 03 FF
2016-09-07 18:23:36.347 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
2016-09-07 18:23:36.349 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Starting initialisation from DONE
2016-09-07 18:23:36.352 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@274956 already registered
2016-09-07 18:23:36.355 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Incoming command class SWITCH_BINARY
2016-09-07 18:23:36.359 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - Received Switch Binary Request for Node ID = 5
2016-09-07 18:23:36.362 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 5: Switch Binary report, value = 255
2016-09-07 18:23:36.365 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2016-09-07 18:23:36.367 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-09-07 18:23:36.369 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint = 0, command class = SWITCH_BINARY, value = 255
2016-09-07 18:23:36.373 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:15348538564:node5:switch_binary to ON [OnOffType]
2016-09-07 18:23:36.379 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Transaction not completed: node address inconsistent. lastSent=2, incoming=255
2016-09-07 18:23:54.357 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 05 03 25 03 00 D2
2016-09-07 18:23:54.367 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-09-07 18:23:54.371 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 05 03 25 03 00 D2
2016-09-07 18:23:54.376 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 05 03 25 03 00 D2
2016-09-07 18:23:54.383 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 03 25 03 00
2016-09-07 18:23:54.388 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
2016-09-07 18:23:54.394 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Starting initialisation from DONE
2016-09-07 18:23:54.400 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@274956 already registered
2016-09-07 18:23:54.404 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Incoming command class SWITCH_BINARY
2016-09-07 18:23:54.434 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - Received Switch Binary Request for Node ID = 5
2016-09-07 18:23:54.438 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 5: Switch Binary report, value = 0
2016-09-07 18:23:54.449 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2016-09-07 18:23:54.451 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-09-07 18:23:54.454 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint = 0, command class = SWITCH_BINARY, value = 0
2016-09-07 18:23:54.457 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:15348538564:node5:switch_binary to OFF [OnOffType]
