A simple scene management: finally a good use of scripts
Great idea for pre-defined scene setpoints (for which using tons of rules is cumbersome) - I wonder if you could somehow make the setpoint values configurable (maybe use XSLT transforms for storing/recalling xml strings with values for each light/dimmer item?). There’s nothing like being able to fine-tune a scene down to the smallest detail, and then just turn on the “Store” switch to remember each setting for future use (instead of having to create another scene or go back into the code every time you want a change)…I have it set up that way using method 3.5 (@rlkoshak 's generic rule) here and ended up using it a lot - I just have a few scenes set up for different times of day/events, and adjust the items in the scene (lamp brightness, colors, effects) at my (or my wife’s) whim…
