As I like to listen the local news in the evening I’ve created a widget to cast the latest local news show to my audio cast device in my bedroom (it works surprisingly well to just listen to a TV news show):
Widget Code
uid: tele_m1_aktuell
tags:
- multimedia
props:
parameters: []
parameterGroups: []
timestamp: Jul 9, 2023, 10:37:13 PM
component: oh-list-card
accordionList: true
colorTheme: blue
mediaList: false
noBorder: false
noShadow: false
outline: true
slots:
default:
- component: oh-list-item
accordionItem: true
accordionItemOpened: false
after: =`Aktuell - ${@'Tele_M1_Aktuell'}`
media: https://ch.az-cdn.ch/static/2.27.2/telem1/device-icons/48x48.png
mediaItem: tru
title: Tele M1
slots:
accordion:
- component: f7-col
slots:
default:
- component: f7-row
slots:
default:
- component: f7-col
slots:
default:
- component: f7-segmented
slots:
default:
- component: oh-button
action: command
actionCommand: https://klive.kaltura.com/env/cluster-1-d.live.nvp1/live/hls/p/1719221/e/1_ljzy3evp/tl/main/st/0/t/aG1N1BfzMxQdZwBcLmPaLw/index-s32.m3u8
actionItem: chromecast_tv_stream
iconF7: radiowaves_right
text: Live TV
action: command
actionCommand: =`https://cdnapisec.kaltura.com/p/1719221/sp/171922100/playManifest/entryId/${@'tele_m1_aktuell_video_id'}/protocol/https/format/applehttp/flavorIds/1_xg1cypuc,1_od67xqgg,1_wsuylbb5,1_f5ktwp0d/a.m3u8?playSessionId=10012dac-3505-6027-844a-90357325306c:76e7250c-ce3c-902a-6451-9770d7dc2578&referrer=aHR0cHM6Ly93d3cudGVsZW0xLmNoL2FrdHVlbGwvc29ubnRhZy0xNDk3Mjc5ODQ=&clientTag=html5:v1.3.0`
iconF7: tv
text: TV
action: toggle
actionCommand: =`http://cdnapisec.kaltura.com/p/1719221/sp/171922100/playManifest/entryId/${@'tele_m1_aktuell_video_id'}/protocol/http/format/applehttp/flavorIds/1_xg1cypuc,1_od67xqgg,1_wsuylbb5,1_f5ktwp0d/a.m3u8?playSessionId=10012dac-3505-6027-844a-90357325306c:76e7250c-ce3c-902a-6451-9770d7dc2578&referrer=aHR0cHM6Ly93d3cudGVsZW0xLmNoL2FrdHVlbGwvc29ubnRhZy0xNDk3Mjc5ODQ=&clientTag=html5:v1.3.0`
actionCommandAlt: = ''
actionItem: Google_Home_Schlafzimmer__Play_URI
active: =@'Google_Home_Schlafzimmer__Media_Control' === 'PLAY'
iconF7: bed_double
text: Schlafzimmer
- component: f7-row
visible: =@'Google_Home_Schlafzimmer__Play_URI' === `http://cdnapisec.kaltura.com/p/1719221/sp/171922100/playManifest/entryId/${@'tele_m1_aktuell_video_id'}/protocol/http/format/applehttp/flavorIds/1_xg1cypuc,1_od67xqgg,1_wsuylbb5,1_f5ktwp0d/a.m3u8?playSessionId=10012dac-3505-6027-844a-90357325306c:76e7250c-ce3c-902a-6451-9770d7dc2578&referrer=aHR0cHM6Ly93d3cudGVsZW0xLmNoL2FrdHVlbGwvc29ubnRhZy0xNDk3Mjc5ODQ=&clientTag=html5:v1.3.0`
slots:
default:
- component: widget:simple_player
control_item: Google_Home_Schlafzimmer__Media_Control
volume_item: Google_Home_Schlafzimmer__Volume
The data I load directly from the web packge via http binding:
UID: http:url:b9394d12a5
label: 📺 Tele M1 Aktuell - (HTML)
thingTypeUID: http:url
configuration:
authMode: BASIC
ignoreSSLErrors: true
baseURL: https://www.telem1.ch/aktuell
delay: 0
stateMethod: GET
refresh: 600
commandMethod: GET
contentType: text/html
timeout: 3000
bufferSize: 2048
channels:
- id: telem1_aktuell_html
channelTypeUID: http:string
label: Tele M1 Aktuell - HTML
description: ""
configuration:
mode: READONLY
With the help of a RegEx
transformation the JSON
with the media resources is extracted into a channel of the thing:
The following JavaScrip
rule identifies the latest show and provides the info required for the ui widget:
configuration: {}
triggers:
- id: "3"
configuration:
itemName: _Tele_M1_Aktuell__HTML_Tele_M1_Aktuell__HTML
type: core.ItemStateUpdateTrigger
conditions: []
actions:
- inputs: {}
configuration:
type: application/javascript;version=ECMAScript-2021
script: >-
const json = items.getItem("_Tele_M1_Aktuell__HTML_Tele_M1_Aktuell__HTML").state;
if (json !== 'NULL') {
const videoAssets = actions.Transformation.transform("JSONPATH", '$..[?(@.video)].assetId', json);
const assetId = JSON.parse(videoAssets).sort().reverse()[0];
console.trace(`Tele M1 📺 - latest video: ${assetId}`);
const filter = `$..[?(@.assetId === \"${assetId}\" && @.video)]`;
const title = actions.Transformation.transform("JSONPATH", `${filter}.title`, json);
const videoKey = actions.Transformation.transform("JSONPATH", `${filter}.video.id`, json);
const kalturaKey = actions.Transformation.transform("JSONPATH", "$..[\""+ videoKey +"\"].kaltura.id", json);
const kalturaId = actions.Transformation.transform("JSONPATH", "$..[\""+ kalturaKey +"\"].kalturaId", json);
console.trace(`Tele M1 📺\nVideo Key: ${videoKey}\nKaltura Key: ${kalturaKey}\nKaltura Id: ${kalturaId}`);
console.trace(`Tele M1 📺 - Aktuell vom ${title} - ${kalturaId}`);
items.getItem("Tele_M1_Aktuell").sendCommand(title);
items.getItem("tele_m1_aktuell_video_id").sendCommand(kalturaId);
} else {
console.warn(`Tele M1 - Keine gültigen JSON-Daten erhalten: [${json}]`)
type: script.ScriptAction
