- Platform information: Mac OS 10.10.5 Yosemite
- Hardware: CPUArchitecture/RAM/storage 2.13 GHz Intel Core 2 Duo
Hi - I am very unfamiliar with command line interfaces (terminal). I am mac based and have just downloaded the zulu dmg which unpacked, ran and installed ok (I can see zulu in my java folder on my mac using finder) I have also downloaded openhab and can see an ‘openhab’ folder in my downloads folder on the same mac.
I can fire up terminal and navigate to the openhab directory. However, when I run ./start.sh in terminal the process starts but then I get the following message:
Launching the openHAB runtime…
Unable to find any JVMs matching version “1.8”.
Java 1.8 or higher is required. Aborting launch.
/openhab/runtime/bin/setenv: line 114: /bin/true: No such file or directory
I’m not sure how to tell what it is looking for in line 114 but it seems to be unable to find any JVM which I assume is a java virtual machine… Do I need to do something extra with zulu to ‘start’ a virtual machine before I run the start.sh command in the openhab folder?
Many thanks for any advice!
