Hi everyone!
I am confuesed. Just for testing purposes I bought some z-Wave sensors (ABUS door and flood), and a wall-plug (Fibaro). The fibaro wall-plug was easy to get running.
Platform information:
Hardware: RaPi 3
OS: Rasbian
openHAB version: 2.5.4
Paper UI Things:
and the Control doesn’t signal any state:
the *.item config file:
Switch C_Office_Power "Lampe" <poweroutlet> (C_Office, gPower) ["Switch", "Switchable"] {channel="zwave:device:1ab4f005:node5:switch_binary"}
Number C_Office_Power_Watt "Steckdosen Leistung [%.0f W]" <energy> (C_Office, gPower) ["Switch"] {channel="zwave:device:1ab4f005:node5:sensor_power"}
Switch C_Office_Door "Tür" <door> (C_Office, gDoor) ["Door", "Alarm"] {channel="zwave:device:1ab4f005:node4:alarm_access"}
Number C_Office_Door_Battery "Türkontakt Batterie [%d %%]" <batterylevel> (C_Office, gDoor) ["Door"] {channel="zwave:device:1ab4f005:node4:battery-level"}
Is there any hope getting these sensors, ABUS SHMK10000 and ABUS SHWM10000 running??
Any idea what’s wrong?
Thank you for your help!
Bernd
The Paper UI is not designed for operation, only administration of OH. I have seen where the Paper UI is incorrect but using the Basic UI works as expected.
5iver
(Scott Rushworth)
May 10, 2020, 12:39am
3
It’s possible that these are not entered into the database correctly, but since it is in there, it is safe to assume that at least one other person is using them and that they would have said something if they were not working.
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/1042
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/1133
Start with turning on debug logging for the binding and confirming the devices are reporting events.
how to start a debug for the binding?
the log doesn’t show any action of the door sensor…
The wall-plug controlled by paper ui takes effect on the log:
but how to start the debug??
You need to be in the Karaf console for those commands.
openhab-cli console
password habopen
. logout
to exit the console.
We have only a limited number of ways to tell people to read the fine manual / documentation.
FipsJr
(SP)
May 29, 2020, 8:10pm
8
I’ve the same problem. I tried to change the configuration so that the device will send it’s updates to the controller but nothing happens.
