Good afternoom everyone, I’m glad to join this community.
I’ve some problems when accessing the openHAB package selection page, when executing the start.bat file it opens the command dialog for OpenHAB server and shows this:
then I put in the explorer the link to access the package selection page but shows:
Access Error: 404 -- Not Found
Cannot locate document: /
so, I readed several post about this issue and I think it could be two possible problems:
the port 8080 is currently used by another PID.
the .sitemap file (if I know what I mean) is missing and this file is the web page of the system or something like that.
So, I’ve applied the command netsat -naob on the (1) item and it shows this:
Try disabling your Lenovo Client Security Solution (I think that this provides the tvttcsd.exe), restart OH2 and try again to access http://localhost:8080 from the same PC running OH2.
Good afternoom Dim and Hans, I tried all the options you gave me without success, I’ve checked the log and I have this answer:
2017-02-13 12:55:54.435 [WARN ] [tty.util.component.AbstractLifeCycle] - FAILED default@2379f4bf{HTTP/1.1}{0.0.0.0:8080}: java.net.BindException: Address already in use: bind
I’ve checked the port usage with a netstat -naob and the port 8080 is currently not used by any PID, the OpenHAB runtime is the 2.0.0 downloaded again from the page and uncompressed. I’ve noted that it isn’t came with a .sitemap file, Are those files the ones who have the visual interface for installing OpenHAB?.
Hi, Valery! I’ve got some problem and trying solve it much time. I was change port and all goes right! For it you should find line “8080” in file “setenv.bat” that lay in “OpenHab\runtime\bin”, and change on another port (I change on 8081).
