Thanks for the good community, I have found a solution to iterate over Things via RESTful service to find out and send alert when Things are offline. However in my current solution I have to enable HTTP basic authentication, and put username and password as clear text in rules file. Since I use GitHub to keep versions of rules, I don’t feel secure include username/password there. So I’d like to ask what are my options if I don’t want to hard code username/pwd in my rules?
val json = sendHttpGetRequest("http://user:password@192.168.1.xx:xxxx/rest/things")
- Is there a way to put username/password as sort of environment property so rules just read from those properties?
- Possible to call RESTful service without authentication (if the call is made from the same IP or within OpenHAB)?
Many thanks in advance!
