Access to karaf with putty after update 2.4 => 2.5 no longer possible
Openhab2.5 is installed on Debian.
Since the update I cannot connect to the karaf console with PuTTY anymore. I get the message
PuTTY Fatal Error
Network error: Software caused connection abort
The port binding is allowed for all IPs.
From the same remote host I can connect to the karaf console via SSH console, but not with PuTTY
But I would prefer PuTTY.
Does anyone have an idea what this is all about?
Thx
Max
This is what you try to do ?
computer A: via ssh => to computer B karaf console
computer A: via ssh putty => to computer B karaf console
I just did a trial and I am able to connect to OH from my notebook using either ssh or putty.
Access to Karaf is not possible without a password due to upstream changes in Karaf.
The default password is habopen
Thank you for your reply.
Yes, that’s what I do:
Computer A => SSH => Computer B karaf console: did work before and work now
Computer A => PuTTY SSH => Computer B karaf console: did work before but since then update no connection can be established
Do you use a password to connect or do you use public, private keys ?
As both use ssh protocol I would expect that both work.
In putty there is a tab to define logging. Can you enable logging this may help to find the root cause.
Thank you Bruce.
Usually the network connection is established before the access data is requested.
But in my case is no TCP connection established at all.
I run into the same problem. There is a log message regarding cipher. This means you need a newer version of putty because older versions do not support the needed cipher to access ssh.
This does the magic.
Thank you very much.
