I have the following items file:
Group LIGHT_DEFAULTS "Group for light default settings"
Dimmer LIGHT_DEFAULT_ILUT "Default for Ilumination Threshold [%d %%]" (LIGHT_DEFAULTS)
Switch LIGHT_DEFAULT_ALLD "Default for all day light [%d %%]" (LIGHT_DEFAULTS)
Switch LIGHT_DEFAULT_ALIL "Default for no ilimination limit [%d %%]" (LIGHT_DEFAULTS)
Dimmer LIGHT_DEFAULT_TIMO "Default for timeout motion [%d %%]" (LIGHT_DEFAULTS)
Dimmer LIGHT_DEFAULT_TOFL "Default for timeout forgot light [%d %%]" (LIGHT_DEFAULTS)
Dimmer LIGHT_DEFAULT_MIDI "Default for minimum dim value [%d %%]" (LIGHT_DEFAULTS)
Dimmer LIGHT_DEFAULT_MADI "Default for maximum dim value [%d %%]" (LIGHT_DEFAULTS)
Dimmer LIGHT_DEFAULT_BTDI "Default for bed time dim value [%d %%]" (LIGHT_DEFAULTS)
Dimmer LIGHT_DEFAULT_DIST "Default for dim step [%d %%]" (LIGHT_DEFAULTS)
here the snippet from my library modules class:
from core.triggers import ChannelEventTrigger
from core.log import logging, LOG_PREFIX
from threading import Timer
import yaml
from core.jsr223.scope import events, items, groups
log = logging.getLogger(LOG_PREFIX + ".this.is.my.log")
class light(object):
def __init__(self, attrJsn, trigJsn):
log.info("<<<items>>>")
log.info(items)
log.info("<<<groups>>>")
log.info(groups)
self.attr_default = 1
self.all_attr = yaml.safe_load(attrJsn)
self.all_trig = yaml.safe_load(trigJsn)
the log when class is loaded:
2020-02-17 11:18:19.973 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Added ScriptEngine for language 'py' with identifier: file:/openhab/conf/automation/jsr223/python/personal/lightControl.py
2020-02-17 11:18:20.191 [INFO ] [jsr223.jython.this.is.my.log ] - <<<items>>>
2020-02-17 11:18:20.195 [INFO ] [jsr223.jython.this.is.my.log ] - {LIGHT_DEFAULT_MIDI: NULL, LIGHT_DEFAULT_TOFL: NULL, LIGHT_DEFAULT_TIMO: NULL, testGU10L: 0, LIGHT_DEFAULT_ILUT: NULL, testGU10M: 0, LIGHT_DEFAULT_ALIL: NULL, LIGHT_DEFAULTS: NULL, LIGHT_DEFAULT_ALLD: NULL, LIGHT_DEFAULT_BTDI: NULL, LIGHT_DEFAULT_MADI: NULL, LIGHT_DEFAULT_DIST: NULL}
2020-02-17 11:18:20.199 [INFO ] [jsr223.jython.this.is.my.log ] - <<<groups>>>
2020-02-17 11:18:20.203 [INFO ] [jsr223.jython.this.is.my.log ] - None
how I see it the group in “items” is null and the “groups” do not contain anything either.
How do I traverse the group defined in items?
Am I totally overseeing something?
