Hi !!
I am trying to acquire temperature values through MQTT but I’m Frequently getting an error
2020-03-31 17:40:00.084 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule 'Set random room temperatures': The name 'Temperature' cannot be resolved to an item or type; line 96, column 5, length 11
2020-04-08 16:28:37.346 [vent.ItemStateChangedEvent] - mqtt_topic_0b04e814_humidity changed from 75.00 to 77.00
2020-04-08 16:28:39.347 [vent.ItemStateChangedEvent] - mqtt_topic_0b04e814_humidity changed from 77.00 to 82.00
2020-04-08 16:28:41.350 [vent.ItemStateChangedEvent] - mqtt_topic_0b04e814_humidity changed from 82.00 to 80.00
2020-04-08 16:28:43.350 [vent.ItemStateChangedEvent] - mqtt_topic_0b04e814_humidity changed from 80.00 to 77.00
2020-04-08 16:28:47.351 [vent.ItemStateChangedEvent] - mqtt_topic_0b04e814_humidity changed from 77.00 to 75.00
You have an Item named mqtt_topic_0b04e814_humidity
That Item gets an update.
That looks like the sort of auto-generated Item that you get when using Simple Mode.
If you are creating your own Items, you probably want to turn simple mode off.
As your Item named Humidity does not appear in your events log, it is not getting updated and so nothing shows in your UI
Well, yes. There’s not much more to say.
The Item that is getting updated is not the same Item that you are viewing in your UI.
That won’t change, unless you change.something.
Perhaps you could look in PaperUI, and see what channel the auto-generated Item links to. Then you could link your non-working Item to the same channel. Then delete the auto Item.
