System details
- Platform information:
- Hardware: Raspberry Pi 4B 4 GiB
- OS: OpenSUSE Leap 15.3
- Java Runtime Environment: openjdk 11.0.11 2021-04-20 LTS, OpenJDK Runtime Environment Zulu11.48+21-CA (build 11.0.11+9-LTS), OpenJDK 64-Bit Server VM Zulu11.48+21-CA (build 11.0.11+9-LTS, mixed mode)
Issue
Given this script:
triggers:
- id: "1"
configuration:
thingUID: xmppclient:xmppBridge:5af0583a7b
channelUID: xmppclient:xmppBridge:5af0583a7b:XMPPIncoming
type: core.ChannelEventTrigger
conditions: []
actions:
- inputs: {}
configuration:
type: application/javascript
script: >+
const publish = actions.get("xmppclient:xmppBridge:5af0583a7b").publishXMPP;
type: script.ScriptAction
I receive this error:
11:25:16.843 [ERROR] [ab.automation.script.javascript.stack] - Failed to execute script:
org.graalvm.polyglot.PolyglotException: ReferenceError: "actions" is not defined
11:25:16.924 [ERROR] [.internal.handler.ScriptActionHandler] - Script execution of rule with UID 'e0a3078ba2' failed: org.graalvm.polyglot.PolyglotException: ReferenceError: "actions" is not defined
My goal is to get a reference to publishXMPP
on the XMPP binding. I’ve seen this post on the subject and also seen this illustrative example which suggest that should work.
What am I doing wrong?
