pi@raspberrypi:~ $ sudo systemctl start openhab2
pi@raspberrypi:~ $ sudo systemctl status openhab2
● openhab2.service - The openHAB 2 Home Automation Bus Solution
Loaded: loaded (/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2018-08-23 01:41:23 CEST; 7s ago
Docs: http://docs.openhab.org
Process: 2024 ExecStop=/bin/kill -SIGINT $MAINPID (code=exited, status=210/CHROOT)
Process: 2022 ExecStart=/opt/openhab2/start.sh server (code=exited, status=210/CHROOT)
Main PID: 2022 (code=exited, status=210/CHROOT)
Aug 23 01:41:23 raspberrypi systemd[1]: openhab2.service: Failed with result ‘exit-code’.
Aug 23 01:41:23 raspberrypi systemd[1]: openhab2.service: Service hold-off time over, scheduling restart.
Aug 23 01:41:23 raspberrypi systemd[1]: Stopped The openHAB 2 Home Automation Bus Solution.
Aug 23 01:41:23 raspberrypi systemd[1]: openhab2.service: Start request repeated too quickly.
Aug 23 01:41:23 raspberrypi systemd[1]: Failed to start The openHAB 2 Home Automation Bus Solution.
Aug 23 01:41:23 raspberrypi systemd[1]: openhab2.service: Unit entered failed state.
