Hi guys,
is it possible to use the “Alles aus!” Panel to act as a switch? I want it to trigger a Homematic switch to shut down all my lights.
Hi guys,
You could try to make a dummy switch in your *,items and combine it with a rule - so when dummy-item recieves OFF => your defined Items also get the OFF command.
I wanted to know the same thing. Turning a dashboard into a button essentially!
