[SOLVED] Add a timer to a rule
Hello guys,
I’d like to set a timer (for about 5min) at the marked line in the code below. How can I do that? It would also be very nice if you could explain your solution because I’m very new in all this and I’d like to understand it :smile:
var DecimalType hue
var PercentType sat
var PercentType brigth
var HSBType licht
rule "Alarm"
Item alarm_aus received command or
Item Srv_Temperatur changed
    Temp_update.postUpdate(new DateTimeType())
        if (alarm_aus.state == OFF) {
                hue = new DecimalType (240)
                sat = new PercentType (30)
                brigth = new PercentType (60)
                licht = new HSBType(hue,sat,brigth)
                Srv_HueColor.sendCommand(licht)
*********************************Timer here**************************************
        else {
          code goes on....
Thanks for your help!
Try using createTimer.
Example:
createTimer(now.plusMinuets(5), [ |
                //do stuff
Hey,
will the “stuff” be executed while the timer is counting down or will the “stuff” be executed after the timer has finished?
Here’s a link to help explain some of the rules using design patterns. At the bottom, you will see additional links that may help for future rules. Rich does a good job explaining everything in detail, hope you find it helpful. If this particular design pattern does not fit your needs then do a search on the forum (key word design pattern) and you should be able to find many other great tutorials that will walk you thru how they work.
EDIT: I forgot to add the link.:upside_down_face:
The stuff will execute after the timer.
Here is a motion rule example that will check the condition of a timer and reset/cancel.
var Timer myTimer = null
rule "Motion OFF"
    Item Motion changed from OFF
    if (myTimer === null) {
        if  (Motion.state == ON) {
            myTimer = createTimer(now.plusSeconds(60), [ |
                if (Motion.state == ON){
                //do stuff
rule "BACK FROM ON"
    Item Motion changed from ON
    myTimer.cancel
    myTimer = null
Maybe consider to do it more straight forward:
rule "Motion"
    Item Motion changed
    myTimer?.cancel
    if(Motion.state == ON)
            //do stuff
Hi, I used the, in my opinion, simplest way:
createTimer(now.plusMinutes(2), [ | ]
But thanks for your help!
