Hi @chris,
could you please add the command class scene_activation for the Fibaro FGRM222 (firmware version 24.24 and up):
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/413
I tried to edit the database but didn’t know all parameters (f.e. “ver”), so I cancelled it to not mess it up.
xml.file if needed:
http://pastebin.com/tbvyNc5q
debug.log:
2016-11-08 20:06:25.827 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 11: Incoming command class SCENE_ACTIVATION
2016-11-08 20:06:25.828 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - Received Scene Activation for Node ID = 11
2016-11-08 20:06:25.829 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - Scene Activation Set
2016-11-08 20:06:25.830 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - Scene activation node from node 11: Scene 14, Time 0
2016-11-08 20:06:25.831 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2016-11-08 20:06:25.831 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-11-08 20:06:25.832 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = SCENE_ACTIVATION, value = 14
I can see the event coming in but are not able to bind that to an item.
Thx a lot.
