- Platform information:
- Hardware: Intel Core i3, 4GB RAM, SSD
- OS: Ubuntu 16.04
- Java Runtime Environment: latest as of Oct 2017
- openHAB version: ? latest stable as of Oct 2017
- Issue of the topic: I cannot configure this Thermostat
I have a Z-Stick Gen5 Zwave controller and a CT101 thermostat. The thermostat is paired with the controller. I see them both in PaperUI - Configuration - Things. Same in HABmin. The controller is detected fine, but the thermostat is not - shows
Z-Wave Node 2 (0098:6501:000C:9.0) ONLINE
Unknown Device
zwave:device:15f9b859c52:node2
I can find a configuration for CT101 at http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/98
but what do I do with it? I exported in OpenHAB2 format. Where do I place the file? I copied it to /etc/openhab2/things/CT101.things, no luck.
Any help would be appreciated. Thanks.
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
