mor_2003
(mor 2003)
1
- Platform information:
- Hardware: Raspberry
- Java Runtime Environment: Java 8
- openHAB version: openhab 2.4
My Problem is that I can’t set the duration of my presence Sensor.
I tested it in ioBroker some weeks ago and there you can set the duration of an Presence sensor but in openhab i can’t see this option why?
Edit:
opus
(Jürgen Baginski)
2
Without telling which sensor how are we supposed to know?
Did you consider to click the “Show more” symbol on PaperUI?
mor_2003
(mor 2003)
3
yes and i use the rtcgq11lm sensor.
Apparently that is a Zigbee device and you are using a non-standard openHAB UI
Which binding are you trying to use for this device? I can think of at least two possibilities supported by different developers.
mor_2003
(mor 2003)
5
I use the deconz binding system and in ioBroker it worked well
opus
(Jürgen Baginski)
6
Maybe because no one considered it necessary so far/volontered to build it in? Remember this is an open source project, everybody can step forward.
