Using locations, can you have a location within a location.
I have a scenario where I have say 2 windows in a room. One window has one actuator, and the other has two actuators as it is wider and i want to ensure a uniform seal when closed.
Currently, I see that 2 groups are needed, one for the room and one for the second window with 2 actuators. Using this approach I should be able to close all windows or both individually.
I would continue to create group items in *.items files just as I do this since 6 years
Note that the Paper UI simply does not (yet) support item management (just very rudamentory right now), so you should either use HABmin or *.items files for that purpose.
So itâs been about a year, and item management is still very rudimentary in the UI. This is kind of sad.
Is there a way @Kai to use items created in the UI, and assign them to groups?
I donât mean locations, I mean logical non-location groups such as âlightsâ or âdoorsâ or âoutletsââŠ
Is this still the only way to populate existing items into a group? (2.3.0-snapshot)
Iâm finding that
I canât use the items file because the item already exists. And i donât really want to have to remove the zWave switches are re-create them manually. What can I say⊠Iâm lazy
Trying to add a âParent Groupâ via the Paper UI, says itâs successful. But doesnât seem to save it
I canât see way to edit groups in HABmin. I can see a Groups field, but itâs greyâed out and canât be edited (Itâs always blank)
