Is it possible to add images, horizontal or vertical lines to Habpanel?
I’ve tried to add the widget “images” but I wasn’t able to figure out how I could use image files that were saved in the directory /icons/classic. I could use this widget to point to a public image by providing the full URL (http://www…).
MDAR
#2
Have you tried putting the images in the HTML folder and using the URL
../static/{filename}
If you want more flexibility, you might want to look at an SVG solution?
Or create your own widget with just the graphic elements in?
