I want to use REST to create new Item on openHAB. i used openhab 1.8.2 and i find that we can use REST link : curl -X PUT --header “Content-Type: application/json” --header “Accept: application/json” -d "test
" “http://localhost:8080/rest/items/test” and i recieved nothing when i run this command on my linux terminal. Please show me the method use REST to create new item. THanks.
Add new item using REST
microchip
(Huynh Thanh Tu)
#1
microchip
(Huynh Thanh Tu)
#3
HABMIN can add new item in webpage, how they can do that? Can i use HTML or Javascript to add a new item. My application require to add new item on the web. Thanks.
rlkoshak
(Rich Koshak)
#6
See the REST API documentation. I think it is possible. You can install the REST API docs through PaperUI under the Misc tab.
