I have glued together a string item so temperature and humidity will display on one line.
I would also like to add some color values so it can be easily seen when the values are outside of set range.
In my sitemap i have defined label color based on temp. But would also like to add humidity so even if temperature is ok but humidity is low - something will be colored red. Wonder if this can be done?
Text item=sense_bigro label="Cinema room [%s]" labelcolor=[sense_bigro_temp<=19="red",sense_bigro_temp<=21="orange", sense_bigro_temp<=24="green",sense_bigro_temp<=25="orange",sense_bigro_temp>25="red"]
