I worked with openhab on my pi3 for a couple of days with an ethernet cable connected to it.
Now i wanted to relocate the pi so i decided to enable the wifi connection.
Since I did that, i cant access the pi (no SHH, no samba connection, no openhab:8080, …)
The pi itself appears to think everything is ok.
My openhab app on phone now only works cause i linked it to myopenhab.org.
Anyone an idea of what this might be?
Or how i van disable wifi again? The option isnt available in the openhabian-config.
I think you need to use rasp-config for these changes. I think the name is correct, just read all the lines at top of screen when you SSH into terminal as it’s listed there.
