Adding Heiman humidity/temperature sesnsor
  • Platform information:
    • Hardware: Windows PC 16GB RAM
    • OS: Windows 8.1 X64
    • Java Runtime Environment: 1.8.0_181
    • openHAB version: 2.1.0
  • Issue of the topic: please be detailed explaining your issue
    • Items configuration related to the issue
    • Sitemap configuration related to the issue
    • Rules code related to the issue
    • Services configuration related to the issue
  • If logs where generated please post these here using code fences:
I’m trying to add a Heiman Z-Wave temperature/humidity sensor to OpenHAB. It shows Node 3 and Node 4 as Unknown Device, which it explains means that the device has not been “fully discovered”. How do I get it to fully discover? I cant get the device to flash its LED whatever I do to the push button. I have put a new battery into the sensor.
Thanks - Rowan
First thing to do is upgrading to the latest snapshot runtime to pick up recent database changes.
