I have a number of Homematic radiator thermostats in the house. I have created an equipment item for each one, and added points for Actual Temperature, Current Mode (auto/manual), Set Temperature, etc. In the semantic model each radiator showed up in the room it was located in, with the point items listed under the equipment item - just like it should.
2 days ago I added the Set Temperature items to a group item (gRadiators) to enable a rule. With one of the points - BathroomRadiator_SetTemperature, when I added it to the group, it became a point of the gRadiators group and was removed as a point of the equipment group BathroomRadiator. As a consequence it doesn’t show up in the UI in the Bathroom, it doesn’t appear in the semantic model under the Bathroom Radiator equipment group.
I checked, rechecked, and re-rechecked the settings of the item, all are exactly the same as the other radiator set point items that behave as expected, i.e. is a point of Bedroom Radiator equipment, and a member of gRadiators.
Anyone have an idea why adding an item to a group would change its semantic model equipment membership?
- Platform information:
- Hardware: Gigabyte Brix MiniPC model GB-BXI7-5775R/MBHM87P-00 BIOS F2. 8GB RAM, 228GB HDD.
- OS: Ubuntu 20.04 LTS
- Java Runtime Environment: openjdk 11.0.8 2020-07-14 LTS
- openHAB version: 3.3 Stable
