Adding node failed on zwave.me UZB1 controller
The security setting won’t make any difference to the initial inclusion which is performed by the controller. This only changes what the binding does for the key exchange. If the controller is not including the device, then I’m not really sure what else can be changed to fix that.
Do you have any other devices to test to see if the problem is with the stick? Are you sure that this stick is definitely an EU version? (I’m assuming you’re in the EU).
Now I did the test with no security, same result, no new thing found. :frowning:
2017-11-01 09:59:56.351 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A 05 01 B4
2017-11-01 09:59:56.352 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWave controller end inclusion
2017-11-01 09:59:56.355 [DEBUG] [ve.internal.protocol.ZWaveController] - Ending inclusion mode.
2017-11-01 09:59:56.357 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 01 B4
2017-11-01 09:59:56.360 [DEBUG] [ve.internal.protocol.ZWaveController] - Stopping inclusion timer.
2017-11-01 09:59:56.363 [DEBUG] [ve.internal.protocol.ZWaveController] - Neither inclusion nor exclusion was active!
2017-11-01 09:59:56.518 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 01 06 00 00 B5
2017-11-01 09:59:56.524 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-11-01 09:59:56.526 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 4A 01 06 00 00 B5
2017-11-01 09:59:56.528 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 4A 01 06 00 00 B5
2017-11-01 09:59:56.530 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 06 00 00
2017-11-01 09:59:56.532 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Add Node: Done.
2017-11-01 09:59:56.533 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInclusionEvent
2017-11-01 09:59:56.538 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=05 01
2017-11-01 09:59:56.540 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 06 00 00
2017-11-01 09:59:56.542 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=AddNodeToNetwork, callback id=0, expected=AddNodeToNetwork, cancelled=false        transaction complete!
2017-11-01 09:59:56.544 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-11-01 09:59:56.545 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 184ms/2258ms
The stick is EU version, “ZMEEUZB1”.
And no, I have no other zwave devices for testing.
I bought the stick together with the POPPs in the same shop.
If nothing works, maybe really the stick has a problem. Then I will try tomorrow to get a replacement.
Hi, I am back again.
I returned the stick and received a new one, plugged in and restarted OH.
I reseted my 2 Popp sensors (10 sec button press), used the “do not use security” mode and started the inclusion, stick is blinking, and try to include one of the sensors:
2017-11-18 10:02:17.327 [DEBUG] [ve.internal.protocol.ZWaveController] - Stopping inclusion timer.
2017-11-18 10:02:17.330 [DEBUG] [ve.internal.protocol.ZWaveController] - Neither inclusion nor exclusion was active!
2017-11-18 10:02:17.335 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - Starting ZWave inclusion scan for zwave:serial_zstick:15f71b6bf6d
2017-11-18 10:02:17.338 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWave controller start inclusion - mode 2
2017-11-18 10:02:17.344 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Setting controller into INCLUSION mode, highPower:true networkWide:true.
2017-11-18 10:02:17.347 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2017-11-18 10:02:17.347 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2017-11-18 10:02:17.350 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A C1 01 70
2017-11-18 10:02:17.353 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A C1 01 70
2017-11-18 10:02:17.363 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 01 01 00 00 B2
2017-11-18 10:02:17.374 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-11-18 10:02:17.392 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 4A 01 01 00 00 B2
2017-11-18 10:02:17.396 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 4A 01 01 00 00 B2
2017-11-18 10:02:17.399 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 01 00 00
2017-11-18 10:02:17.402 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Add Node: Learn ready.
2017-11-18 10:02:17.413 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInclusionEvent
2017-11-18 10:02:17.426 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=C1 01
2017-11-18 10:02:17.436 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 01 00 00
2017-11-18 10:02:17.438 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=AddNodeToNetwork, callback id=0, expected=AddNodeToNetwork, cancelled=false        transaction complete!
2017-11-18 10:02:17.439 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-11-18 10:02:17.443 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 86ms/170ms.
2017-11-18 10:02:47.343 [DEBUG] [ve.internal.protocol.ZWaveController] - Stopping inclusion timer.
2017-11-18 10:02:47.345 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Ending INCLUSION mode.
2017-11-18 10:02:47.348 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2017-11-18 10:02:47.348 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2017-11-18 10:02:47.351 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A 05 01 B4
2017-11-18 10:02:47.351 [DEBUG] [ve.internal.protocol.ZWaveController] - Ending inclusion mode.
2017-11-18 10:02:47.353 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 01 B4
2017-11-18 10:02:47.356 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWave controller end inclusion
2017-11-18 10:02:47.367 [DEBUG] [ve.internal.protocol.ZWaveController] - Stopping inclusion timer.
2017-11-18 10:02:47.371 [DEBUG] [ve.internal.protocol.ZWaveController] - Neither inclusion nor exclusion was active!
2017-11-18 10:02:47.509 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 01 06 00 00 B5
2017-11-18 10:02:47.511 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-11-18 10:02:47.514 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 4A 01 06 00 00 B5
2017-11-18 10:02:47.524 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 4A 01 06 00 00 B5
2017-11-18 10:02:47.527 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 06 00 00
2017-11-18 10:02:47.537 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Add Node: Done.
2017-11-18 10:02:47.540 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInclusionEvent
2017-11-18 10:02:47.545 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=05 01
2017-11-18 10:02:47.548 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 06 00 00
2017-11-18 10:02:47.552 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=AddNodeToNetwork, callback id=0, expected=AddNodeToNetwork, cancelled=false        transaction complete!
2017-11-18 10:02:47.558 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-11-18 10:02:47.561 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 206ms/206ms.
and again, no new thing found!!!
I am really lost, what goes wrong here?
Unfortunately I have no idea what is going wrong. I only can proove to you that the POPP is working with zwave :sunglasses::grinning:
Well, it looks like the problem was sitting in front of the screen :upside_down:
I was always pressing the button on the smoke detector for the inclusion… well, NO!!! I need to press the small button on the rear of the device PCB which was covered by the baseplate Dammed!!!
NOW I understand
Have fun.
