I’ve added the Samsung TV binding to my OpenHAB2 installation and have successfully got mute working by adding the following line to my sitemap using Eclipse SmartHome Designer:
I can’t however get other items working such as channel and volume. I’ve tried adding the volume item but the item does not display when browsing the sitemap and Eclipse SmartHome Designer underlines Dimmer and shows the following line as having an error.
Thanks Yann. I was using the item type from the Samsung binding documentation and not the sitemap Element type. Both the slider and setpoint elements now work for volume:
I still can’t get the channel item working. This sitemap entry shows the setpoint control and the the channel number increasing/decreasing but the channel on the tv does not change:
Hi Yann - I’ve changed the configuration to the example as you’ve suggested without success. Here are the log files when i use the sitemap to change the channel
openhab.log [ERROR] [rnal.service.RemoteControllerService] - Could not send command(s) to device on 10.1.1.22:55000: org.openhab.binding.samsungtv.internal.protocol.RemoteControllerException: Connection failed
events.log [ItemStateChangedEvent ] - samsungtv_tv_1b2a66c1_ae28_42ae_b7b3_8df1a954cfa2_channel changed from 13 to 14
I did a little research and if you have H series of Samsung TV this will not work. It seems that H series have different encrypted protocol and it’s not connection on 55000.
I looked everywhere but it seems there is no solution to this.
I don’t believe there is anything that can be done. I’d suspect that given Samsung have their own HA ecosystem that they’d prefer not to make things work work with other HA environments.
