I need to setup this item with only xml configuration:
I know how to do it with sitemaps but my binding requires xml configuration.
Can anyone show me the best way to achive it?
Hi, maybe you can use the exec binding?
I was searching for a way to use the exec-binding (openHAB 1.x) together with the setpoint element to create an easy way to show a value and modify it, e.g for volume control, temperture-set, etc.
The posts I found where always referring to a combination of number items and rules to make this work.
After some more research I found the following way which I would like to share:
Create php file and hand over parameters via argument $argv[x] to carry out the actual command for the change:
Cheers
I use iotivity binding. I don’t know if using another binding would interfere with my program?
