chrdal
(Chrdal)
October 7, 2020, 5:54pm
#1
Hi all,
I registered at opensmarthouse and want to add one new devices.
Eurotronic Temperature and Humdity Sensor https://eurotronic.org/wp-content/uploads/2020/09/Temperature-and-Humdity-Sensor-Z-Wave-Plus_BDA-Web.pdf
but I have two problems.
First I don’t find the xml file in /var/lib/openhab2/zwave . Both are missing here (but I see them on the paperui)
Second I don’t find the Add Button opensmarthouse
Best regards,
Christoph
Wlecome!
What version of openHAB are you running?
That means the devices have not been fully discovered by the binding. This is usually an issue with battery operated devices that need to be woken up many times for discovery to complete,.
You may need additional account permissions. Unfortunately, Chris is on vacation. If you can post the xml file we can work with you to get the devices added if needed.
chrdal
(Chrdal)
October 8, 2020, 5:20am
#3
attached you find the xml file. You were right. It took a night until it was available.
grml I cannot upload xml files as new user. I have to post it
<node>
<homeId>0xd9a5734d</homeId>
<nodeId>16</nodeId>
<version>4</version>
<manufacturer>0x148</manufacturer>
<deviceId>0x1</deviceId>
<deviceType>0x4</deviceType>
<listening>false</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>1000</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_BATTERY</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<commandClass>COMMAND_CLASS_TRANSPORT_SERVICE</commandClass>
<commandClass>COMMAND_CLASS_SENSOR_MULTILEVEL</commandClass>
<commandClass>COMMAND_CLASS_WAKE_UP</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_SECURITY</commandClass>
<commandClass>COMMAND_CLASS_SECURITY_2</commandClass>
<commandClass>COMMAND_CLASS_SUPERVISION</commandClass>
<commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<associations/>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<associations/>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SENSOR_MULTILEVEL</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_ROUTING_SENSOR_MULTILEVEL</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<configParameters/>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<COMMAND__CLASS__FIRMWARE__UPDATE__MD>
<versionSupported>3</versionSupported>
</COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</entry>
<entry>
<COMMAND__CLASS__SENSOR__MULTILEVEL>
<version>5</version>
<versionSupported>5</versionSupported>
<sensors>
<entry>
<multilevelSensorType>RELATIVE_HUMIDITY</multilevelSensorType>
<multilevelSensor>
<sensorType>RELATIVE_HUMIDITY</sensorType>
<initialised>true</initialised>
</multilevelSensor>
</entry>
<entry>
<multilevelSensorType>TEMPERATURE</multilevelSensorType>
<multilevelSensor>
<sensorType>TEMPERATURE</sensorType>
</multilevelSensor>
</entry>
<entry>
<multilevelSensorType>DEW_POINT</multilevelSensorType>
<multilevelSensor>
<sensorType>DEW_POINT</sensorType>
</multilevelSensor>
</entry>
</sensors>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__SENSOR__MULTILEVEL>
</entry>
<entry>
<COMMAND__CLASS__SECURITY>
</COMMAND__CLASS__SECURITY>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<versionSupported>2</versionSupported>
<zwPlusVersion>1</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_SLAVE_SLEEPING_REPORTING</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<autoSubscribeGroups/>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<version>2</version>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>5.3</protocolVersion>
<applicationVersion>0.1</applicationVersion>
<hardwareVersion>1</hardwareVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>328</deviceManufacturer>
<deviceType>4</deviceType>
<deviceId>1</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<maxGroups>2</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__WAKE__UP>
<targetNodeId>1</targetNodeId>
<interval>600</interval>
<minInterval>600</minInterval>
<maxInterval>86400</maxInterval>
<defaultInterval>3600</defaultInterval>
<intervalStep>120</intervalStep>
</COMMAND__CLASS__WAKE__UP>
</entry>
<entry>
<COMMAND__CLASS__BATTERY>
<batteryLevel>100</batteryLevel>
<batteryLow>false</batteryLow>
</COMMAND__CLASS__BATTERY>
</entry>
<entry>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors>
<int>3</int>
<int>9</int>
<int>15</int>
<int>17</int>
</nodeNeighbors>
<lastReceived>2020-10-08 00:30:30.681 UTC</lastReceived>
</node>
Best regards,
Christoph
The XML file looks fine to me but trying to create the database device gives an error.
I will need to look at this further this evening after my workday.
@chrdal
Apparently that device is already partially in the database but not available because it is incomplete. That is why I could not add it.
I will see if i can complete the entry.
I finished adding the device. Normally @chris exports the database once a week but he is on vacation. The new entry would then appear in a snapshot build.
For future reference, the entry is here.
chris
(Chris Jackson)
October 9, 2020, 8:35am
#7
I managed to do an update this morning…
Sorry to tag you on your vacation.
chrdal
(Chrdal)
October 9, 2020, 9:37am
#9
Hey Chris & Bruce,
thank you very much. Is there a possibility to test is here? Were can I get the file and were do I have to copy it?
Br,
Christoph
We need to wait until a new snapshot binding is built. I believe the install script can let you manually install the binding.
I really should verify that this evening but am evaluating a crisis at work currently.
EDIT: I cannot easily verify the script because my test system is on OH3 currently.
chris
(Chris Jackson)
October 9, 2020, 1:24pm
#11
No probs Bruce. We have good internet access at the moment, but we’re heading further into the back of beyond over the next couple of days so things may head south again after tonight.
chris:
No probs Bruce
Does the wife & family agree with that too?
chris
(Chris Jackson)
October 9, 2020, 1:50pm
#13
Yeah - we’re not up to too much - just a bit of walking and driving around the far north of Scotland so I’ve a little time in the evening at least
chrdal
(Chrdal)
October 10, 2020, 11:00am
#14
Hi all,
I tested it with the snapshot build #69 and it is working. Thank you very much for this great support.
Bruce & Chris, thanks for your support / help.
Best regards,
Christoph
