I installed the latest openHab image on my raspberry in cable mode. Now i would like to switch to wifi. How/ where can i adjust the configuration?
this is a raspberry configuration issue and not related to OH2, maybe this will help:
openhabian-config has a menu option to configure the wifi network. If you are not running openHABian, raspi-config can also set the wifi configuration.
Do you really absolutely need to move to wifi? The wired solution is far more reliable and not susceptible to interference or scrambling… Stay with wired, if you can
